Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Diagnostic Tools
Old Dec 9, 2004 | 10:30 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Diagnostic Tools
What are the best value tools for reading error codes? Are there any adaptors for laptops and software to use or what do you guys use? I know a lot about repairing my older trucks but my 99 F-150 is getting older and I would like to be able to take care of it like I do my older trucks.
Old Dec 9, 2004 | 11:24 AM
wiseguy's Avatar
wiseguy
I've got a code reader that I bought 12 years ago, that just beeps and lights an LED to show the codes. It's not sophisticated, but it does work. I took my car up to AutoZone and they scanned it using their scanner, and printed out the results. They were the exact same results that I got with my cheapie scanner, except for the one line description that their scanner gave. I was looking at the Auto X-Ray 600 or something like that. It is very nice, but a little too pricey for me now. Maybe in a couple of months......
Old Dec 9, 2004 | 12:10 PM
FordTrucksKickGM
Once you get the codes how do you figue out what the code means?
Old Dec 10, 2004 | 06:22 AM
wiseguy's Avatar
wiseguy
The AutoZone scanner actually give you a one sentence description of the problem. With my cheapie scanner, I have to look up the numerical error code in a manual. The cheapie does come with a 6 page booklet that list the error code and gives a brief description of the error. My manual is just more thorough, as it gives testing procedures for each code.
Old Dec 10, 2004 | 06:30 AM
Torque1st's Avatar
Torque1st
Posting Legend
Whatever tool you get you will still need a service manual. A service manual is the first "tool" you should buy for any vehicle.
Old Dec 10, 2004 | 12:21 PM
FordTrucksKickGM
What are some good models of cheepy code readers?
Old Dec 10, 2004 | 09:14 PM
Piffery1's Avatar
Piffery1
Creader (for OBD II). Got mine on eBay for about $30 + shipping. Harbor Freight Tools (check online) had them on sale recently for $39 (free shipping if order total is over $50). Comes with a booklet explaining how to use and what the codes mean. It won't tell you exactly which part is bad (I don't think any of them do) but, knowing the codes, having a manual for your vehicle, plus using the forums for help with problems should get you going.
Piffery1
Old Dec 11, 2004 | 03:48 PM
rebocardo's Avatar
rebocardo
I have the www.autoxray.com EZ-2000 scanner. It is a far cry from what I was used to using while working at dealerships, but, for <$200 (bought at northerntools.com) it suffices. It gives a brief description of most faults. Having live data capture of sensors would be nice, but, usually not needed.
I was getting a 1999 Dodge Cummings diesel running that died. It still was not right and pulled up a fault code# that I could not find on-line at any OBD-II site or in the repair manuals. I stumbled across it using Goggle on a Dodge site. Turned out to be what I thought, the injector pump, so it was towed to a Dodge dealer since there are a few tools I needed for the job that I did not have. $3500 later ($2200 for a rebuilt injector pump) it was on the road again.
So, having a code scanner and manual can be nice, having a forum to seek help is even better, even if it is a Dodge or Jeep.
Old Dec 13, 2004 | 03:00 AM
War_is_my_Shepherd's Avatar
War_is_my_Shepherd
I have the "INNOVA 3100" OBDII code reader. I read some good reviews online and bought it. Haven't actually used it yet.
Old Dec 15, 2004 | 10:09 AM
RobertJohn's Avatar
RobertJohn
And where can I get the INNOVA 3100 code reader and is it compatable with the PSD ??
Old Dec 16, 2004 | 01:25 AM
DonsFx4's Avatar
DonsFx4
Yo, any cheapo readers out there that work with the new CANbus data link?? My cheapo Actron won't work in my '04 ("link error" message).
I thought all ODBII readers were built to one standard, and come to find my friends at Ford "upgraded" to CANbus.
Any help would be greatly appreciated!!
Old Dec 16, 2004 | 10:20 AM
Hangfire's Avatar
Hangfire
You gotta be kidding!
Old Dec 17, 2004 | 09:07 PM
someday's Avatar
someday
from what i researched the auto xray 6000 was the best bang for the buck. the reason i was going to buy it was because the newer superduties(04+) use CAN instead of OBDII so even some of the expensive scanners could not do what the 6000 could. also the 6000 as well as others can check all older models if you buy optional adapters or you could buy the whole bundle
Old Dec 19, 2004 | 09:26 AM
njtinman2's Avatar
njtinman2
Talking obd2
obd2 software for a laptop the the software and cable is under $100.00
the link is http://www.obddiagnostics.com/index.html
Old Dec 20, 2004 | 04:47 PM
RangerRuss's Avatar
RangerRuss
There are some nice units that will interface with your laptop computer that are not outrageous. The difference between a code reader and a scanner is the "live" data from the sensors in your monitored systems. As Eric stated, you will still need a shop manual to determine what the acceptable readings should be however this sure cuts down on diagnostic time. I believe it is Auto XRay that makes the software and sells the cables that interface between your truck and the computer.
I have found shop manuals for my trucks in CDRom format on E-Bay for under $10.
At home I use an Actron C9145 which has proved to be satisfactory.
Hope this is helpful.
Russ
