The right size tires
Old Dec 9, 2004 | 06:01 AM
sweet03cobra's Avatar
sweet03cobra
I just bought my 04 cobra and it has some little punk tires on it. What size do most of you all have. I want a good all terain/street tire, so if your answer is 35" swappers don't bother. I just want it to look a little better with out getting silly. What did all of yours come factory with?
Old Dec 9, 2004 | 09:58 AM
waynerb's Avatar
waynerb
"04 cobra" "35inch swappers"? Are you trying to ask about tires for a truck or car? Because I have both. Bullitt and F250 03 4x4 6.0PSD.
Old Dec 9, 2004 | 10:17 AM
sweet03cobra
ah damn, my bad. I meant my 04 PSD. I guess I'm just use to talking about my cobra. Sorry. That would be truck tires.
Old Dec 10, 2004 | 12:01 AM
sweet03cobra
It came with 265-75-16's
Old Dec 10, 2004 | 12:03 AM
sweet03cobra
It came with 265-75-16's, so what do you all think I could got with just to fill up and make it look a little better using the stock rims.
Old Dec 10, 2004 | 10:02 AM
huntercgr's Avatar
huntercgr
Most seem to go with 285's. They fit perfect with no rubbing. I know mine does.
Old Dec 10, 2004 | 11:31 AM
sweet03cobra
how much does it change the speedometer?
Old Dec 11, 2004 | 10:51 AM
utahtom's Avatar
utahtom
Many report the 285's correct the read of the speedo- Stranger things could happen!
Old Dec 11, 2004 | 10:56 AM
SBV45's Avatar
SBV45
If the odometer is correct and the speedo needle is 2mph fast and the 285 correct the speedo, what does that do to the odometer, fuel mileage?
Old Dec 11, 2004 | 11:36 AM
sweet03cobra
it must help gas mileage and put less mileage on the truck
Old Dec 11, 2004 | 11:40 AM
SBV45's Avatar
SBV45
Help me out with tire sizes here. Is the 285 bigger in tire diameter or tread width than a 285? On a tire description of 265/75 R16, what do each set of numbers stand for? I know the R16 stands for Radial ply and 16" diameter rim, right?
Old Dec 11, 2004 | 11:43 AM
sweet03cobra
265=width
75=% of width =height of sidewall
Old Dec 11, 2004 | 12:02 PM
sweet03cobra
Let me clarify that. The first # is the width in mm, then the second # is measured by the percent of the width, which creates the height of the tire. So, if you bump up the first #, it will get wider but also increase the height of the tire also. That is why low pro tires will be like 315-35s, they just take a small fraction of the width.
Old Dec 12, 2004 | 01:22 AM
tristankc's Avatar
tristankc
Indeed, 265 or 285 is the width in millimeters and 75 measurement of the sidewall which is the percentage of the width. Like was said before.
So on a 285/75R16 the side wall heigth is 285 * 0.75 = 213.75 mm = 8.42 in.
16 + 8.42 + 8.42 = 32.84" tire. (8.42 gets added twice, 2 sidewalls in the overall diameter)
The general findings from people are that the speedos with the factory tires are 2 mph off the actual speed at highway speeds. This is what is has been for me on two different trucks. The 285's have corrected for that 2 mph. The question was asked how this affects fuel economy. On both of my trucks, when switching to 285's, I lost 0.9 mpg. Doing all of the math, 0.7 mpg is from correcting the speedometer. The other 0.2 I surmise is from the extra width and weight of the tire.
Old Dec 12, 2004 | 01:25 AM
sweet03cobra
(SNIP) I thought it would of help, seeing the truck has so much tq. I thought it would help the over gearing. My bad.
