The right size tires
Old Dec 12, 2004 | 12:35 PM
PAN's Avatar
PAN
I run LT 285-75-16 BFG AT's, but LT305-70-16's will fit on stock rims with no leveling kits. I've seen them rub the drivers side front mud flap but that aint' no biggy. Take if off and grind the backside down alittle bit to where it sits closer to the fender. Some trucks are off just alittle bit and they will rub like mine, but some are just fine and don't rub like my neighbors
Old Dec 12, 2004 | 11:37 PM
sweet03cobra's Avatar
sweet03cobra
is there anything in between those 2? I don't want to remove or grind anything. Anyone got some pics with the 285-75-16's on?
Old Dec 12, 2004 | 11:41 PM
PAN's Avatar
PAN
285's will fit for sure without rubbing. That is what I run, I have pics in my gallery
Old Dec 13, 2004 | 12:22 AM
sweet03cobra
Yep, that is what I want. Are those BFG all terains?
Old Dec 13, 2004 | 09:06 AM
4x4Mark's Avatar
4x4Mark
BFG has a 295/75-16. I've got a set on order. They are just a hair larger than the 285's - 33.2" tall and 11.5" wide according to BFG. They maintain the same weight capacity as as the OEM 265/75-16's E-rated. While looking for which tires to get, I noticed about a .5" variation in the various brands of 285's. The BFG 295's were similar in size to some of the other mfg's 285's. My belief is I'll start out just a bit over 33", but after tire wear, will drop down below - I should averaged about 32 3/4" for the life of the tire.
Mark
Old Dec 13, 2004 | 10:38 AM
PAN's Avatar
PAN
Yes they are 285 BFG AT"s. I wanted to put on 305-70-16's but didn't know if they'd fit or not. Now i know they will and I thjink i'm going to upgrade and get them.
chadillac80
Jan 12, 2014 04:57 PM
sweet03cobra
Dec 19, 2007 12:54 AM
98cobra1064
34
Jul 5, 2006 02:28 PM
67fastbackfreak
41
Nov 1, 2004 07:35 PM
