Bronco II Ford Bronco II
Better Carb.
Old Dec 9, 2004 | 05:14 AM
slimbronco's Avatar
slimbronco
Better Carb.
Hey my 84 2.8L Bronco II doesn't get the best gas mileage in the world just curious if anyone has any suggestions on carb that will be better for gas. I was told to look at a 4bbl fuel economy holley. If anyone has suggestions that would be helpful I would appreticate it.
Old Dec 13, 2004 | 01:44 AM
slimbronco's Avatar
slimbronco
does anybody know anything about the 4BBl carb convertion for the 2.8L engine looking at doing but curious if anyone has done it yet?
Old Dec 13, 2004 | 07:34 PM
Ken00's Avatar
Ken00
Sorry, I never head of a 4 bbl conversion, can someone help??
Old Dec 14, 2004 | 02:36 PM
dirtybroncoii's Avatar
dirtybroncoii
Here is what I did to my 85. I took off the 2bbl carb and but a 2bbl from a 1978 Mustang with a 302, you want to talk about being able to scream
Old Dec 14, 2004 | 03:43 PM
slimbronco's Avatar
slimbronco
what didi you use for a gasket? When ever I go in and try to buy a gasket for my carb it's the wrong one the gasket doesn't fit. The carb hangs over the gasket causing a vaccum problem I have an old gasket on it but it's leaking. This is the reason I want to upgrade to the 4BBL but if you can help me find the right gasket and stuff I will go the way your talking about. Do you know what carb it is that you pulled from the mustang?
Old Dec 15, 2004 | 12:08 AM
dirtybroncoii
I used a Motorcraft model 2100, but if you want fuel efficiency use a model 2700 Variable Venturi Carb. As for the gasket, the bolt holes are the same as the stated carbs and will bolt on. I suggest getting a roll of cork and trace the bottom of the carb you intend on using and make a gasket. Hope this helps
Old Dec 15, 2004 | 07:36 AM
slimbronco's Avatar
slimbronco
thanks bro that helps a ton!
Old Dec 15, 2004 | 11:31 AM
dirtybroncoii
All of those carbs where used in 1978 so that might help narrow down the search. I have a model 2100 just sitting around here some where.
Old Dec 16, 2004 | 01:28 AM
slimbronco's Avatar
slimbronco
would you be willing to sell the 2100? and how much?
Old Dec 16, 2004 | 10:25 AM
dirtybroncoii
First I have to make sure that I actually have one that is not in use. Second I will need to know your address so I can calculate shipping costs Private Message me with that info.
imlowr2
13
Apr 5, 2008 09:31 AM
bigtymer77
Jun 7, 2006 07:06 PM
lettereat
Aug 3, 2004 06:02 PM
youngguy
Jul 22, 2003 09:11 PM
Fordnut
Dec 19, 1999 06:10 PM
