I pulled engine code18...need translation
Old Mar 23, 2006 | 05:37 PM
MustangGT221's Avatar
MustangGT221
Ok I know which connector you're talking about now...
The 89 I have...has the 4 connectors you speak of...my 95 has a slightly different harness, its 1 connector but the same idea.
So the resistor is before the engine harness connector....sounds good I'm gonna check into it when I get a chance.
I gotta figure out whats wrong with this damn truck, been over 2 years trying to figure it out.
Old Mar 30, 2006 | 04:24 PM
MustangGT221
Well I'm now able to get my trouble codes...and I don't have anything.
The only real thing I have is code 85 but that is because my CANP solenoid is disconnected right now. That shouldn't be interfereing here (I get it on KOEO).
I've got a mustang a9l computer on it right now and I've driven it about 10-15 cycles and I havn't gotten any CM codes (hoping for CM code 18). I used to have code 18 on KOER but that went away when I took the SPOUT connector off and taped the wires together (some kind of bad connection in the SPOUT connector).
I cut my 89's wiring harness open and looked at how it's wired and saw the 22k ohm resistor section and how it's all put together.
I'm not really sure what to do now since I don't have a code telling me any direction to go in. Any suggestions?
Old Apr 16, 2006 | 10:14 AM
MustangGT221
So i've been working at this over the last 2 days...
I put the voltmeter to my old 89's wiring harness and got 22.1k ohms of resistance between the negative coil wire and the plug on the fender (end of engine harness).
I did the same thing on my 95's harness and I get virtually nothing for ohms. I don't think the 22k ohm resistor is in the engine harness on my 95. So I reconnected the harness, and checked the resistance between pin 4 and the coil negative - and get like 12k ohms.
I don't know where the 22k ohm resistor is on my 95 - apparently it's gotta be near the power distribution box somewhere.
Why would the ohm reading be less? Does that mean the resistor is in need of replacement or a bad spot in the wire....?
Old Apr 16, 2006 | 07:25 PM
95X15's Avatar
95X15
For info 95 EVTM does not show resistors in lead to PCM or tach but the 88 EVTM does (22K in PCM lead DG/Y and 1.8 K in DG/Y lead to tach on 5.0, 5.8 and 7.5 only, not 4.9). The T/Y lead from negative side of coil goes to 1) instrument cluster and 2) ignition module, then to PCM.
Hope this helps.
The T/Y lead is shown in 95 Wiring in EVTM. EDIT
Old Jul 1, 2016 | 01:08 AM
vjsimone's Avatar
vjsimone
Did you ever get your truck running right? Tracking an 18 code myself on an 85' 5.0L EFI myself.
Old Jul 1, 2016 | 12:29 PM
Lead Head's Avatar
Lead Head
This thread is over 10 years old. You'd have better luck making your own.
Old Jul 1, 2016 | 02:40 PM
vjsimone's Avatar
vjsimone
But my truck is 30 years old.... Great reading though.. Yeah, understand, but every now and again I get lucky... Just researching this code and applying everyone’s knowledge, when I have exhausted all avenues, will definitely post my issue. thanks.
rangersvt04
3.0L V6
52
Mar 2, 2022 12:41 PM
welove2drive
Oct 27, 2017 06:19 PM
Rennisreaper
57
Jul 29, 2017 05:33 PM
Tepco
Jul 23, 2017 06:08 PM
aaronrodgers38
Feb 28, 2017 10:25 AM
