Sponsored by: Auxito
IAC Valve
Old Dec 8, 2004 | 02:08 PM
ryanjap33's Avatar
ryanjap33
IAC Valve
Hey Guys,
My 98 with the 5.4 keeps stahling out immediately after I start it. If i lightly keep my foot on the gas it idles fine and runs fine. No englne light has come on and it has been doing this for a while now. I have been told about the IAC (Idle Air Control) Valve. Can any on you fill me in on what exactly this is, does and where it is. Thanks Guys, I appreciate it
Old Dec 8, 2004 | 02:51 PM
mizzleman's Avatar
mizzleman
The IAC is located at the back of the throttle body near the firewall. It's a cylinder about an inch in diameter and about 3-4" long with an electrical connection on one end. It's held on by two 8mm bolts. It controls the amount of air needed by the engine at idle. A faulty one will cause the problems you are having. It's fairly easy to replace. Some guys have had some luck cleaning the valve itself, but only in the short term. Better to just replace altogether.
Old Dec 8, 2004 | 03:13 PM
PaulC's Avatar
PaulC
Do a site search on IAC replacement. You will find many posts/threads on the topic. If you can change a spark plug, you have the technical ability to replace the IAC valve.
Old Dec 8, 2004 | 03:24 PM
ryanjap33's Avatar
ryanjap33
Thanks Guys, I have one on order and will be installing it tomorrow night.
Jlckb5
Nov 7, 2011 07:50 AM
Bobby82490
1997 - 2003 F150
Dec 4, 2009 02:15 PM
scrapyardking
1983 - 2012 Ranger & B-Series
Mar 18, 2008 08:29 PM
razor_jim
Aerostar
15
Jul 25, 2005 02:11 AM
JEV
17
Jun 9, 2005 08:28 PM
