skipping
Old Dec 7, 2004 | 07:20 PM
firemen122's Avatar
firemen122
skipping
Hello to all I am new to this forum been surfing here a while and fixed a lot of things on my 97 4x4 c/c auto by research. Now I could use some help. I have replaced all glow plugs and relay truck starts great now, but have an skip that comes and goes at idle mostly when colder sounds like one cylinder goes dead puffs heavy smoke then idles fine. Then comes back last about 3-10 seconds at atime. truck has 65 horse bully dog chip,d/p,and afew other minor things. Thanks for your help.......
Old Dec 7, 2004 | 11:07 PM
Pikachu's Avatar
Pikachu
Under valve cover harness, perhaps....
Old Dec 7, 2004 | 11:10 PM
Kwikkordead's Avatar
Kwikkordead
Pikachu, I am going to disagree and say it's a failing injector o-ring. If the wiring harness were failing it would not inject at all and therefore no smoke.
Old Dec 8, 2004 | 09:09 AM
firemen122's Avatar
firemen122
thanks for replys wiring harnesses replaced and o-rings replaced by previous owner trying to stop smoke any other thoughts?
Old Dec 8, 2004 | 09:12 AM
Kwikkordead
I still think it's a failing injector then. Possibilities are he tore the o-ring when reinstalling the injector to the injector going bad internally.
Old Dec 8, 2004 | 10:03 AM
firemen122's Avatar
firemen122
thanks kwik I fail to mention that raising rpms up to about 1200 or more skip dissapears. Is worse when cold, after warm seldom skips at idle and only does it when first started, whether cold or hot. How would i find out which injector is culprit.Only way I know is to find coldest bank on exhaust upon initial start of day, any other suggestions?
Old Dec 8, 2004 | 09:43 PM
Kwikkordead
Without using a breakout box the only way that I know of is to remove the valve covers, start the motor and one by one unplug the injectors until you find the offending one. Then since you are already there it's a quick matter to fix it.
EDIT: You can also unplug the wiring harness at the valve cover gasket one by one before you pull the covers. You'll kill more than one at a time, but at least you will know which side to take off.
Old Dec 8, 2004 | 09:50 PM
barebackjake's Avatar
barebackjake
that almost sounds like a cracked nozzle, im going with a bad injector sounds like solinoid is opening but not closing, i agree with quick and going process of elimination
Old Dec 10, 2004 | 12:00 PM
firemen122's Avatar
firemen122
thanks to all for their knowledge. When I slow down in a few days I will try to pin down which injector..
fordff
18
Dec 2, 2013 07:06 PM
lincolnboy73
17
Aug 18, 2011 09:28 AM
sfyarborough91
Modular V8 (4.6L, 5.4L)
Mar 17, 2011 08:05 AM
Jbrown8988
Oct 2, 2009 01:47 PM
vee-eight-fords
Dec 9, 2006 04:07 PM
