Pulley & Belt Alignment Question...
Old Dec 7, 2004 | 08:00 AM
jmbatlanta's Avatar
jmbatlanta
Question Pulley & Belt Alignment Question...
The past couple of days I have heard a squealing noise from what I think is the belt. Upon inspection, looking from the side, it appears the tensioner is cocked towards the front of the truck. It is definently not in line with the rest of the pulleys. As for the squeal, it is very wet here today and once the truck was running the squeal stopped.
I am thinking the squeal may be a result of moisture and this is normal - is this correct? and the unaligned tensioner is a problem even though the belt travels fine.
Historically, is the tensioner a problem and what is the best way to fix an out of aligned tensioner if it is indeed a problem?
Old Dec 7, 2004 | 08:10 AM
Kwikkordead's Avatar
Kwikkordead
Get that tensioner assembly replaced before it tears away and really causes some damage.
The squeal is caused by the belt being dragged at an angle across the pulley. Same principle as a car doing a 4 wheel drift=tires squealing, making LOTS of HEAT.
Old Dec 7, 2004 | 08:14 AM
fedextech's Avatar
fedextech
replace the tensioner and the belt. the tensioner has failed and when it runs at angle like that, it will cause undue stress on the belt and the belt will fail. the belt squeal is from the tensioner not doing it's job.
Old Dec 7, 2004 | 08:19 AM
Spaznaut's Avatar
Spaznaut
Yeah get that fixed. I left mine alone after I saw that one rib had jumped on an 8 rib belt. That rib flew apart and took out the wiring on my electric fans. Always happpens at worse times and places.
Moralon't let something small turn into something big.
Old Dec 7, 2004 | 09:09 AM
jmbatlanta's Avatar
jmbatlanta
Thanks for the help guys. Is it o.k. to stay with the Ford OEM or is there a better alternative? I know I can change the belt but is the tensioner something I can do myself?
Old Dec 7, 2004 | 10:52 AM
Spaznaut's Avatar
Spaznaut
Think it has one bolt with a guide nipple to keep it from turning in place? Should be fairly easy.
Old Dec 7, 2004 | 09:41 PM
jmbatlanta's Avatar
jmbatlanta
Job done! $107 for belt tensioner and new belt from NAPA. Had to buy some torx drives but once I had these the job took about 30 minutes. Had to loosen the lower pulley to get the old tensioner out. Once out, the old tensioner was full of what appeared to be carbon - it was definently gone. New one is on and doing it's job - biggest thing is that it is perfectly in line with the rest of the puleys. Hopefully I averted a catastrophic failure by getting this done now. No more squeal...
The old belt is in the truck as a spare...
Thanks for all of the help.
Jim
Old Dec 9, 2004 | 11:26 AM
Spaznaut's Avatar
Spaznaut
Grats.
Glad ya got a NAPA belt. Forgot about that. Did many autozone advanced ones til I learned they stretch so bad.
twangysmitty
24
Feb 20, 2024 06:03 AM
catto95
Apr 6, 2017 12:04 AM
Icefan71
1997 - 2003 F150
Jan 15, 2017 07:52 AM
CoreLokt
Mar 14, 2016 06:13 PM
BarnieTrk
Nov 8, 2010 04:47 PM
