timing
Old Dec 6, 2004 | 09:57 PM
chrono4's Avatar
chrono4
timing
i have a 88 f150 5.0 and i was just need to know how to check for slack in timeing. if a timeing chain were to break on the 5.0 would the valves be far enough out to bend them? i just want to check up on this for my personal peace of mind. thanks, chrono
Old Jan 23, 2005 | 06:36 AM
XylemXorro's Avatar
XylemXorro
I'm not an expert by any means, but I have heard several times that the timing chain should be replaced on these if there is any kind of doubt as to it's condition. You will have to access the chain to check for slack (refer to chiltons) and the possibilty of the valves getting damaged......100%.
Old Jan 23, 2005 | 07:04 AM
EPNCSU2006's Avatar
EPNCSU2006
You can check for slack without pulling the cover as follows: Turn the engine with a socket wrench on the damper bolt on the front of the engine until the engine gets to TDC timing mark on the damper. Then pull the cap off the distributor, then while watching the rotor, begin to turn the engine in the opposite direction. Stop turning when you first see the rotor begin to move. Now look at the timing marks on the damper, and if it is more than 5 degrees from where you started, then it would be a good idea to replace the timing chain.
Old Jan 23, 2005 | 08:19 AM
donnie1987's Avatar
donnie1987
hello, i would like to have info on the gap of the points and gap of spark plugs for a 1987 ford 350 and 400 engines. please reply. thank you. donnie
Old Jan 23, 2005 | 12:29 PM
chrono4's Avatar
chrono4
donnie, to ask a new question you need to start a new thread.
Old Jan 23, 2005 | 02:30 PM
stevef100s's Avatar
stevef100s
Besides that, there's no such thing as a 87 350 or 400 engine, and if there was, it wouldn't have points.
Old Jan 24, 2005 | 08:42 PM
desertdave35's Avatar
desertdave35
350 or 400 engine??? Did you see a bowtie on this page? I don't think so ,
"What you mean my diesel doesn't have spark plugs?"
Old Jan 26, 2005 | 03:20 AM
matt17's Avatar
matt17
timing chain slack
tell me if im wrong,i thought 302,351 were not interference motor(valve benders)!
Old Jan 26, 2005 | 03:28 PM
chrono4's Avatar
chrono4
thats what i was hoping but i am not sure still now that we got a black sheep in the crowd,lol
Old Jan 27, 2005 | 04:33 AM
XylemXorro's Avatar
XylemXorro
Matt17
Well, could you explain the freak happening of my rods bending when my timing chain broke on my 351W???
Old Jan 27, 2005 | 05:41 AM
desertdave35
Xylemxorro- if you bent your rods, something else was going on in your engine. I tend to believe you would bend a valve before you would bend a rod on a broken timing chain.
Old Jan 27, 2005 | 08:27 AM
ronclark's Avatar
ronclark
It is possible to bend valves on a 302 if the timing chain jumps and you change the distributer timing to compensate so that it runs and it jumps again. Once had a truck in the shop with a bad timing chain. Fixed the chain reset the timing and the truch ran but was skipping bad. Ran compression check and 0 compression on 3 cylinders. Service manager claimed that the chain was on wrong because a 302 wouldn't bend valves if the chain jumped. Had to pull the heads on my own time to prove him wrong. Three bent valves!!! Customer admitted to advancing the distributer to get the truck running to bring to the shop and the chain jumped again in route.
