Idle ?
Old Dec 6, 2004 | 06:26 AM
bulldog3531's Avatar
bulldog3531
Idle ?
i have a 98 explorer sport 4.0 SOHC. Wanted to know if anybody knew what it should idle at when it is in park and when it is in gear? Thanks for any info.
Old Dec 6, 2004 | 09:36 AM
87 XLT's Avatar
87 XLT
Take a look at the emissions sticker under the hood.
Old Dec 6, 2004 | 11:53 AM
bulldog3531
I Looked On My Lunch Break. Did Not Say Anything About What The Idle Should Be. Is There Any Other Place I Can Look Or Can Any Tell Me What It Should Be? Thanks For The Help.
Old Dec 7, 2004 | 08:36 AM
bulldog3531
can anyone tell me the correct idle or about what it should be at when in park and in gear? thanks
Old Dec 7, 2004 | 01:48 PM
87 XLT's Avatar
87 XLT
Strange that it's not on the emissions sticker? My guess is around 800 RPM's. If you have a Haynes manual it should tell you in chapter one. How fast is it idling?
Old Dec 7, 2004 | 02:23 PM
bulldog3531
i do not have a manual. it idles around 1000-1100 rpm. is that to high or is that about right?
Old Dec 7, 2004 | 03:57 PM
87 XLT's Avatar
87 XLT
My guess is that warm idle should be around 800.
I'd check and make sure the throttle body is clean & throttle plate is closing all the way & check for lean codes.
Old Dec 8, 2004 | 05:49 AM
bulldog3531
The trottle body is good. I do have the CEL on. Auto zone said it was the #1 O2 sensor. Whould that cause it to idle a little high? Thanks for the info.
Old Dec 8, 2004 | 02:09 PM
87 XLT's Avatar
87 XLT
Which O-2 code did they pull? Theres a couple of them. If it as an O-2 lean, thats your high idle & you need to figure out why it's running lean.
Not sure, but I think the SOHC has a bad habit of having leaking intake manifold O rings. Do a search on that.
Old Dec 8, 2004 | 02:33 PM
bulldog3531
I justed replaced my intake o-rings this weekend it fixed the rough idle and hard start on cold mornings. The CEL was on before I did that so my guess it was running lean. Auto Zone did not give me a code they just said it was bad. As soon as the holidays are over I will get around to replacing the O2 sensor when i get time. Thanks for the help and info 87 XLT. As soon as i replace it I will let you know.
Old Dec 8, 2004 | 03:01 PM
87 XLT's Avatar
87 XLT
You're welcome, and good luck with it.
