1964 f-250 292 question
I just got a 1964 f-250 with a blown (rod through block) engine. This engine is not the original engine. The block casting shows (B9AE) which means a 1959-1960 292. My question is the distributor is on the front of the engine all the y-block pictures I've seen show the distributor on the rear of engine by the firewall, what gives? Does this sound right? If not what do you think I have? Thanks
Yes, It has ford pressed into the valve cover and is bolted around the edges of valve cover. no holes thru cover. Any numbers I should look for on block to confirm what I have. Thanks
the date code on the block shows it a 1959-1960 blockNow I need to know what engine or engines would be a direct bolt in with the setup I have. This truck has a automatic trans. I dont know if it's a cruise-omatic or something else. I don't what to change out bell housings or anything I just want to make this as painless as possible
That;s fairly simple, a 1960 352 car V8 engine..The 59 would have been the police interceptor car engine, if it's blue a 1960 to 64 352 will bolt right up to your setup, but only those 4 years cars engines....Janet
PS...in my younger years i wasted much much money and time, getting an engine and bolting to a stupid unknown automatic transmission, heck buy the unit!! It's only or supposed to be no more than 200 more or so...Janet
Actually an automatic rebuild kit is pretty cheap, let's say if the salvage yard engine and tranny together transmision is unknown, people think its 1000 to build an automatic, those kits are cheap!!! And anyone can rebuild one, buy the chiltons with pictire diagrams, and don't screwup like me, and forget the servo for the rear band for reverse, hehehe!! Oh yes, ive learned from mistakes.....Janet
Ki-Adi-Mundi
05-23-2015 12:19 PM
raider69guy
06-24-2013 07:25 PM
pmh
16
12-06-2012 06:22 AM
