Recently my PSD has been missing slightly. Then it started missing severly and lost all power. Had it towed to Ford -- they said it was the batteries. Replaced them and it ran fine for about 1/2 hour. Turned truck off for about 15 minutes. When I started it back up it started missing slightly and then gradually (over the course of 2 - 4 miles) began missing severly and lost all power -- to the point it was unable to pull itself home. Now it won't start at all. Any thoughts, comments on what the problem could be?
I haven't checked my fuel pump yet. The tach is not arching above 1 on crank (shouldn't it be between 2 & 3?). I do have a little blue/white smoke but it has been fairly cold here? I got two codes last night P0001? and P0470 which is exhaust pressure sensor malfunction I think. I can't find a P0001 -- the closest to it was P0010 which is the CPS right?
