2.0 vs 2.3
Old Dec 7, 2004 | 05:06 PM
canzus's Avatar
canzus
Okay, lets shoot some of the misinformatoin in the head while
we have a chance... There two 2.0L SOHC all iron engines, one
is the 2.0L "EAO", which came in the Capri and the early Pintos,
then there in the 2.0L "LIMA", which is the smaller bore brother
of the 2.3L "LIMA". Now for the Mazdas, the original small pick up
was called the Courier, which was all Mazda, with a different grill...
It had a 1.8L SOHC with an aluminum head, and later, a 2.0L, also
with an aluminun head, 1977 (?) saw the first all Ford built Couriers
which came with the 2.3L Lima engine...
SteveL
Old Dec 7, 2004 | 11:38 PM
tomw's Avatar
tomw
And they say restrictor plate engines are limited to NASCAR. Heck, we have them with Ranger trucks!! Aluminium plates to match carbs to manifolds. Heavens, what will be next, ... sheesh, I don't know how to finish this up.
Ah, well, the carb'd 2.0 is no match for an EFI 2.3. The 2.3 will fall behind the 2.5 .. Don't let me get started on those twin-plug thingies....
The mainfolds hung off the 2.3 are varied. Pinto, Mustank, Ranger... Mazda, too.
At least they are not the Deutsch 2.0 from the early Pinto (71-73). Tho, it did have mech lifters, and was able to rev nice..
tom
Old Dec 8, 2004 | 04:47 PM
canzus's Avatar
canzus
Actually, the 2.0L EAO, your "deutsch", or the 3 bearing cam
continued production in Europe until it was replaced by the Zetec,
which was around '89 or so. And it's nickname is the "Pinto"...
SteveL
Old Dec 9, 2004 | 10:03 AM
Dodge41's Avatar
Dodge41
SteveL
Mazda wasnt the orginal small pickup truck, as mini trucks were built as early as the late 50's from Japan. The orginal piston powered mini truck from Mazda/Ford was the b1600. As far as the couriers go, yes the first one was offered in 72 with the 1.8l sohc. The b1600, b1800, and b2000 mazda s(72-84) all obviously used mazda drivetrains. The later fords courier, 77 and up, used the 2.3l. The later Ford couriers, up till 82, were not all Ford built as they shared the same bodies as the 77 -84 b2000. Now there are newer Ford couriers ( Yes they still make them overseas) , but I dont know what engines they are using, probably diesels.
Old Dec 10, 2004 | 07:24 PM
canzus's Avatar
canzus
Thats not what I meant, sorry if you parsed it wrong,
but the Mazda was the original FORD mini pick up, not the
first mini pick up...
SteveL
Old Dec 10, 2004 | 11:56 PM
Dodge41's Avatar
Dodge41
Naw, you didn't make me mad. I just like Couriers (one of the few fans left lol )
Old Dec 11, 2004 | 05:40 PM
srod's Avatar
srod
Not quite, the 2.3Tempo/Topaz is a push rod engine, it's a 200cid
6 cylinder with 2 of them removed, just about as bullit proof as the 6,
just less power...
SteveL
Steve
I guess I stand corrected,
In 1994 I bought a new Tempo with a 2.3 engine the Ford Salesman told me it was the same engine Ford was using in the Ranger. That's where I got the idea they were the same.
The Tempo is still in my family, I gave it to my son about four years ago, he's using the car to drive to college. the 2.3 in those cars are a great little engine..
Greg
1981 F100 Custom SB Inline
Old Dec 12, 2004 | 07:00 PM
canzus's Avatar
canzus
They are the same...
size and manufacturer...
anyway, the 2.3/2.5 OHV are dead nuts reliable,
which is "a good thing" as Martha would say...
SteveL
Old Jan 6, 2009 | 12:37 PM
lil red ranger's Avatar
lil red ranger
Ford used 2.0 motors starting in 1983. ( Their own) I have an 88 ranger that had a 2.0 that was in bad shape. The 2.0 is an under bored 2.3. Internal parts won't interchange but most external parts will. I just had the flywheel redone with a new ring gear and resurfacing and put it on a 2.3 that I had souped up to put in my 90 ranger. The five speed tranny from the 88 is the same five speed tranny I have in the 90.
lil red ranger
Old Jan 9, 2009 | 07:16 PM
Old Rob's Avatar
Old Rob
The early 80's rangers came with a 2.0 Lima engine. The head was round port intake. There was two round port heads used, one for the 2.0 and one for the 2.3 rangers. The 2.3 RP ranger head had bigger valves. The intake manifolds were of dubious design and performance was not part of it. They both had the same head bolt, water and oil patterns.
The 2.3 engine in the taurus etc is the HSC engine, a completely different design, nothing interchanges.
The latest 2.3 rangers are the Dura Tech engine, again completely different.
Old Jan 10, 2009 | 09:45 AM
lil red ranger
Old Rob,
You are correct, I believe both of mine are the Limas.
The real prblem facing me right now is the MAZDA M50D-R1 from both the 88 and 90 have two different style clutch slaves. I bought the clutch kit for the 90 and the slave from the 88 does not have the same throw out bearing. 88 thru 92 are supposed to interchange. Wonder if someone had put an earlier 5 speed in the 88?
Are we allowed to post a picture of the new build Lima?
lil red ranger
Old Jan 20, 2009 | 12:35 PM
jimdandy's Avatar
jimdandy
The three tower head was used on the Pinto 2.0 engines from 1972 to 1974. They were not used on 2.3 engines. The heads on the 2.0 and 2.3 later engines are the same and can be interchanged. The blocks cannot. The early 2.0 with the three towers has the distributor located close to the front of the block. On the 2.3 is is further back.jd
Old Jan 26, 2009 | 03:39 PM
  #28
Old Rob's Avatar
Old Rob
The rangers around the 81 thru 84 years had a round port head. there were two versions, one for the 2.0 Lima and one for the 2.3 lima. They both had a corresponding manifold that will not bolt to any of the earlier or later 2.3 lima'sThe exhaust was the same.
bowtieboy77
1983 - 2012 Ranger & B-Series
Nov 7, 2013 03:02 PM
pintoches
General Automotive Discussion
41
May 6, 2008 03:18 PM
pintoches
4 Cylinder Engines
16
Apr 4, 2007 04:33 PM
rotwyler
4 Cylinder Engines
Mar 19, 2007 01:16 AM
