Are 2.3 and 2.0 same carb mount. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Reload this Page >
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-05-2013, 05:09 PM
bowtieboy77
bowtieboy77 is offline
bowtieboy77 is starting off with a positive reputation.
I have a 86 ranger chassis with a 88 ranger 2.3 engine in it bolted to a m5r1 5speed. I am currently rebuilding it for a cheap fuel daily driver. I have emissions test here but since the chassis is a 86 I am exempt. My problem is the aisian 2bbl that was on it is not known to be preferred due to all the emission controls. I have tried to figure out what carb I can use on it knowing adapter plates are going to be needed. I have pretty much decided I am going new carb and leaning strongly towards the weber 32/36 progressive with either manual or elec choke. I know the head ports are different shape between the 2.3 and 2.0 but wondering if the carb mounting is the same. I can find weber kits for 2.0 but have not seen any for 2.3. Also any other suggestions as to what carb to use I will consider.
Old 11-05-2013, 07:15 PM
ranger pat's Avatar
ranger pat
ranger pat is offline
ranger pat has a very good reputation on FTE.ranger pat has a very good reputation on FTE.ranger pat has a very good reputation on FTE.
If your 2.3L is a 88, then it is fuel injected. Do we have to assume you have swapped the 2.0L intake onto the 2.3L and now want a better carb than the 2.0L came with? The Aisian carb was actually about as good as the carb that came on the early 80's 2.3L engines.
Old 11-05-2013, 08:56 PM
bowtieboy77
No it is rare but there were some 2.3 in 88 probly early 88 that were carbureted. It has made getting engine parts a pain.
Old 11-05-2013, 08:58 PM
bowtieboy77
All I need to know is the rectangle carb mounting the same on 2.3 intakes and 2.0 intakes. If so I will by the weber carb kit for the 2.0 liter and it should work.
Old 11-06-2013, 08:47 PM
ranger pat's Avatar
ranger pat
You might try some parts houses or search online to see if they take the same carb mounting gasket. In the US, all the 2.3L's were EFI starting in 1985 to meet US emission laws. There were some 2.0L's in the US that got a 2 bbl Aisian carb in 87 and 88 or 89. I see you are located in Canada, ah?
Old 11-07-2013, 03:02 PM
bowtieboy77
Thanks joe
Thanks for the reply Joe. I was able to contact carbs unlimited and they were able to find a weber conversion for a 86-88 ranger with 2.0 that they said would work.
xon2013
32
11-05-2016 07:59 AM
Gembone
12-11-2014 12:28 PM
armashby
10-26-2014 03:45 PM
rustybug13
07-27-2012 02:37 PM
ssj7kids
48
06-04-2011 01:08 PM
Quick Reply: Are 2.3 and 2.0 same carb mount.
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
