loud truck
Old Dec 4, 2004 | 04:07 PM
mike9762's Avatar
mike9762
loud truck
my truck is 1977 f250 351m.truck is really loud mufflers are new flowmasters and tail pipes are new.the headers are rust colored but intact.could it be just need to tighten the headersto the manifolds?
Old Dec 4, 2004 | 09:24 PM
ford390gashog's Avatar
ford390gashog
i would not worry about it
Old Dec 6, 2004 | 12:45 AM
crack's Avatar
crack
no its a ford, its ment to be loud
Old Dec 6, 2004 | 09:35 AM
wickymustang's Avatar
wickymustang
Why are you asking about tightening the headers to the manifolds? Is it a loud tick like a leak or are you saying that tightening the headers will quiet the exhaust? If everything is tight then everything is normal, with flowmasters and tips it should be loud, like a real truck.
Old Dec 6, 2004 | 05:07 PM
mike9762's Avatar
mike9762
loud truck
its a loud tick.i thought it was an exhaust leak and thats the only place i think it could be from
Old Dec 6, 2004 | 07:00 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Lout tick sounds like exhaust leak for sure. Try tightening and if that don't do it, I'd examine and find where the leak is. If too much cold air sucks into the hole when you shut down, you could warp a valve if the hole is large enough. If the headers are rusted through, you might be able to have someone grind/polish and either weld or braze the hole shut.
Old Dec 8, 2004 | 08:29 AM
tukes48's Avatar
tukes48
ya it could be the gasket to. but make sure u check everything over. an exhaust leak can spell trouble
kemerick
Jun 22, 2016 11:09 AM
lewistg
Oct 31, 2015 06:56 AM
CR3999!
6.7L Power Stroke Diesel
Jul 11, 2015 03:43 PM
NidStyles
31
Aug 7, 2014 08:28 AM
