Coolant drain plug in block?
Old Dec 4, 2004 | 10:14 AM
FARM69's Avatar
FARM69
Is there a coolant drain plug in the block on the 300? I flushed my rad and took the lower elbow off and refilled the system with the proper amount of coolant and water, but it is still rated too hair. I had been putting water in before this to get my by, so that would explain the high amount of water. Thanks
Old Dec 4, 2004 | 10:49 AM
Georgia 66 f100's Avatar
Georgia 66 f100
huh?explain more please
Old Dec 4, 2004 | 11:14 AM
tetraruby300's Avatar
tetraruby300
There is no "service" drain plug on the block. There are several plugs pressed in on the side and one in the rear of the block as well as in the rear of the head. You may have an air pocket stuck in the block? Warm it up and let park your truck on both an incline for a few hours and then do the same for a decline. I know it sounds hokey but that's what I had to do to get the air out of my heater core.
Old Dec 4, 2004 | 02:55 PM
FARM69's Avatar
FARM69
Sounds like a plan, I would have thought that the cooland would have ran out of the lower hose. The 302 has a coolant drain plug on the block right? Is that plus just like a regular plug? Do you advise messing with the pressed plugs or are they not worth the trouble.
Old Dec 4, 2004 | 05:37 PM
Phrogman46's Avatar
Phrogman46
FYI
The pressed plugs are known as freeze plugs and there is no reason to remove them unless there rusty or your rebuilding the motor. To remove the air you can hook up a vac pump to the radator.
Old Dec 4, 2004 | 06:38 PM
FARM69's Avatar
FARM69
Yeah,I didn't think you messd with them if they are pressed. Thanks for the help
Old Dec 4, 2004 | 09:08 PM
63redtudor's Avatar
63redtudor
The drain plug is on the right (passenger) side of the block. Look under the exhast manifold.
Edwin
Old Dec 4, 2004 | 09:55 PM
tetraruby300
I stand corrected. There is a threaded plug of sorts between the last two freeze plugs on the passenger side as mentioned.
Old Dec 5, 2004 | 10:09 AM
FARM69's Avatar
FARM69
Oh, so there is a drain plug then?
Old Dec 5, 2004 | 12:16 PM
tetraruby300
Here-> http://tetraruby300.freewebsitehosti.../drainplug.htm
Old Dec 5, 2004 | 03:23 PM
FARM69's Avatar
FARM69
Ahh, couldn't be better. Thanks for the image. I dont have the truck with me, but one last question... Is it easy to get at?
chetspencer
Jun 23, 2013 12:19 PM
greentree ford
Nov 15, 2012 04:24 PM
tom302
Sep 10, 2010 08:49 AM
Wheels
Modular V10 (6.8l)
Jul 1, 2007 11:39 PM
pawpaw
1983 - 2012 Ranger & B-Series
Jul 27, 2005 10:59 AM
