gear marking
Old Dec 4, 2004 | 06:19 AM
wyldstallyn73's Avatar
wyldstallyn73
gear marking
Have done a couple of gear setups myself using machinists dye (prussian blue) for gear marking compound with good results so far. Is this acceptable to use???? I just kind of came up with the idea myself and went ahead and did it without checking into it.
Old Dec 4, 2004 | 09:05 AM
mark a.'s Avatar
mark a.
Try G.M. marking compound, you can get it at any dealership. You will be able to see the pattern a lot better
Old Dec 4, 2004 | 09:29 AM
teds74ford's Avatar
teds74ford
As far as it hurting, I don't see why. I have used moly grease to setup gears, and have had no problems, so I don't see why you would. Obviously, marking compound would be the best.
Old Dec 5, 2004 | 02:42 AM
wyldstallyn73
Visibility is my only issue, the teeth that are "painted" dont really show that well untill you study them for a while-the clean teeth show a pretty good pattern for me because the blue dye gets left on them. I tried the moly grease and it didnt work at all for me. I will stick with my dye unless someone can come up with a convincing argument not to.
Old Dec 5, 2004 | 03:55 AM
sixpack2639's Avatar
sixpack2639
Prussian Blue won't hurt anything if you don't clean it off the gears. All it is is a dye in a light grease base. Carl (Machinist for 20 odd years)
Obowersox26
Sep 17, 2016 09:21 PM
sean9049
Feb 18, 2016 08:44 PM
rickm15752
Jan 5, 2012 05:00 PM
amish77
Apr 30, 2005 11:33 AM
Greywolf
Nov 5, 2002 05:38 PM
