slow hi boy
Old Dec 5, 2004 | 07:44 PM
fordfury469's Avatar
fordfury469
yeah you should be able to go way over 60 ive got the same set up as you do.
Old Dec 5, 2004 | 07:49 PM
76hi-boy's Avatar
76hi-boy
thanks i dont know what the problem is, when we got it on the free way we get it up to around 60 and its screamin and makin lots of funny noises
Old Dec 5, 2004 | 07:51 PM
fordfury469
how many rpms are you pulling at 60 again.
Old Dec 5, 2004 | 07:56 PM
76hi-boy's Avatar
76hi-boy
around like 25
Old Dec 6, 2004 | 11:19 AM
fordfury469
oh well thats normal then
mines the same way but mine dont sound like its gonna blow up. Is it engine noise or something else maybe rear end tranny etc.
Old Dec 6, 2004 | 04:52 PM
76hi-boy's Avatar
76hi-boy
I just bought an edelbrock 600 cfm carb a performer manifols and a cam kit so well see if that helps.
Old Dec 7, 2004 | 01:00 AM
fordfury469
well sure cant hurt, more power is always better.
Old Dec 7, 2004 | 08:17 AM
rakent's Avatar
rakent
76hi-boy,
I would find out what the existing problem is before changing manifolds and carbs. Like most have indicated, your truck should easily be able to run past 60 mph in stock form.
Is your motor generally healthy otherwise? Have you run a compression test?
Old Dec 7, 2004 | 10:20 AM
fordfury469
yeah mine is healthy, just swapped heads for ones with smaller combustion chamber and rebuild them. one cylinder burns some oil, but other than that it healthy, it has edelbrock intack and 600 cfm carb and i dont know what cam is in it.
Old Dec 7, 2004 | 02:09 PM
76Forder's Avatar
76Forder
my F250 with a lil less than stock tires 3.73 rear and a 460/c-6 ill turn about 2800 at 65mph, on top of that it sounds like my old 76 hauls *** compared to toping out at 60, i can wrap my speedo out at 100 mph easy......of course my gas goes ALOT quicker
barrycm
Aug 30, 2011 11:38 AM
76hi-boy
Mar 27, 2005 09:22 AM
76hi-boy
Offroad & 4x4
Feb 7, 2005 08:07 PM
76hi-boy
Dec 23, 2004 10:34 AM
Mil1ion
Feb 23, 2002 06:51 PM
