Spark Knock
Old Dec 3, 2004 | 10:52 AM
geno87_69's Avatar
geno87_69
Spark Knock
Anyone get substantial spark knock when accelerating hard on cold motor?
Happens in the 3-4K RPM range.
I have a 5.4 3V with 23k on the clock, and it just started this new thing..
Any TSB's, SSM's, etc?
Thanks..
Old Dec 3, 2004 | 11:09 AM
jperea's Avatar
jperea
There is a thread going on this..
https://www.ford-trucks.com/forums/s...d.php?t=313470
FYI - Ford Special Service Message under 497000 - Engine Noise Concern
18091 2004 F-150 5.4L - TICKING NOISE FROM UPPER ENGINE
SOME 2004 F-150 VEHICLES EQUIPPED WITH A 5.4L 3-VALVE ENGINE MAY EXHIBIT A TICKING NOISE FROM THE UPPER ENGINE. IF THE NOISE IS LIGHT, COMES FROM THE TOP FRONT OF THE ENGINE, OCCURS AT IDLE, GOES AWAY ABOVE 1000 RPM, AND IS MORE PRONOUNCED AS OIL TEMPERATURE INCREASES (ABOVE 160F/71C), REPLACE THE CAM PHASER WITH KIT 3R2Z-6A257-AA. IF THE TICKING NOISE DOES NOT MATCH THESE SYMPTOMS, CHECK INSTEAD FOR COLLAPSED LASH ADJUSTERS AND/OR CAM SHAFTS THAT MAY BE GALLED.
EFFECTIVE DATE: 08/20/2004
Old Dec 3, 2004 | 11:15 AM
geno87_69's Avatar
geno87_69
I saw that thread.
This however is between 3-4K. And appears to me to be a hellacious spark knock..
Old Dec 3, 2004 | 11:19 AM
jperea's Avatar
jperea
Hi ho, hi ho, off to the dealer you go.......
Old Dec 4, 2004 | 07:34 AM
Dave MK's Avatar
Dave MK
What is a spark knock?
00GT
Escape & Escape Hybrid
Jul 9, 2012 10:11 AM
gcpommom
Aerostar
Oct 15, 2011 08:53 PM
llangebartels
1983 - 2012 Ranger & B-Series
Aug 15, 2011 06:57 PM
bobsford
Mar 4, 2005 11:55 AM
webigon
Oct 9, 2001 04:07 PM
