04 Ticking Noise Upper Engine
Old Dec 1, 2004 | 09:35 AM
Waldonian's Avatar
Waldonian
FYI - Ford Special Service Message under 497000 - Engine Noise Concern
18091 2004 F-150 5.4L - TICKING NOISE FROM UPPER ENGINE
--><!--SOME 2004 F-150 VEHICLES EQUIPPED WITH A 5.4L 3-VALVE ENGINE MAY EXHIBIT ATICKING NOISE FROM THE UPPER ENGINE. IF THE NOISE IS LIGHT, COMES FROM THETOP FRONT OF THE ENGINE, OCCURS AT IDLE, GOES AWAY ABOVE 1000 RPM, AND ISMORE PRONOUNCED AS OIL TEMPERATURE INCREASES (ABOVE 160F/71C), REPLACE THECAM PHASER WITH KIT 3R2Z-6A257-AA. IF THE TICKING NOISE DOES NOT MATCH THESESYMPTOMS, CHECK INSTEAD FOR COLLAPSED LASH ADJUSTERS AND/OR CAM SHAFTS THATMAY BE GALLED.
EFFECTIVE DATE: 08/20/2004
SOME 2004 F-150 VEHICLES EQUIPPED WITH A 5.4L 3-VALVE ENGINE MAY EXHIBIT A TICKING NOISE FROM THE UPPER ENGINE. IF THE NOISE IS LIGHT, COMES FROM THE TOP FRONT OF THE ENGINE, OCCURS AT IDLE, GOES AWAY ABOVE 1000 RPM, AND IS MORE PRONOUNCED AS OIL TEMPERATURE INCREASES (ABOVE 160F/71C), REPLACE THE CAM PHASER WITH KIT 3R2Z-6A257-AA. IF THE TICKING NOISE DOES NOT MATCH THESE SYMPTOMS, CHECK INSTEAD FOR COLLAPSED LASH ADJUSTERS AND/OR CAM SHAFTS THAT MAY BE GALLED.
</P>
Old Dec 2, 2004 | 09:21 AM
Sully04 F150 4x4's Avatar
Sully04 F150 4x4
Interesting. Looks like it's time to take my truck in. I have 16K miles and the noise hasn't went away. BTW, where did you get this info?
Old Dec 2, 2004 | 09:40 AM
Waldonian's Avatar
Waldonian
The information came from pulling OASIS on a 2004 XLT 4x4 SCrew built 4/2004 and searching the symptom categories. OASIS pulls VIN specific info as well as TSBs, SSMs (like posted) and recall info. Something that a dealership or Ford, Lincoln, Mercury employee could do for instance.
Old Dec 2, 2004 | 10:15 AM
Brix92's Avatar
Brix92
04 ticking noise upper engine
What is OASIS? Is it a website, and if so, cna you give the site address?
Old Dec 2, 2004 | 10:49 AM
Waldonian's Avatar
Waldonian
On-Line Automotive Service Information System (OASIS) is what the dealer pulls when you bring your vehicle in - gives them all the detailed specific info. It's a Ford internal site - not open to the general public.
Old Dec 2, 2004 | 04:13 PM
Dunk's Avatar
Dunk
What the difference between this noise and the injectors working? Mine sounds the same hot or cold and the engine itself is dead quiet except you can hear the injectors clicking and you have to pay close attention to even hear those..
Old Dec 2, 2004 | 08:08 PM
Paul f150's Avatar
Paul f150
Same here. I was told that the ticking wasn't lifters like I thought but injector noise and concidered normal. I hope thats right.
