1970 drop. Please help!
Old Dec 30, 2004 | 10:38 AM
4Cammer72's Avatar
4Cammer72
the idea we're talking about is to change the size of the bolt pattern. then you can choose from a better array of wheels. i already looked up the part numbers at ford and the bearings and races are the same part # i just havent set the rotors side by side to see if the total diameter and facing are the same.if they are wheel choices would increase alot.anybody got 20 minutes to go stand at the parts counter and look them over?
Old Dec 30, 2004 | 03:04 PM
4Cammer72's Avatar
4Cammer72
HEY RANGER 240, i got a chance to do a comprison of the rotors and so far its a no go on the swap from a 83 light duty to our style 65 to 79 even though the bearings are the same . the diameter is smaller and the rotor is thinner.im going to go to my friends junk yard and do some measuring this weekend to see if the ibeams are even close. maybe it can be done that way. i'll let y'all know what i find later.
Old Dec 30, 2004 | 03:23 PM
Red2003XLT's Avatar
Red2003XLT
Why don't you just have your rotors re-drilled to the knew bolt pattern?
Old Dec 30, 2004 | 05:18 PM
4Cammer72's Avatar
4Cammer72
the way the facing is on the 83 style rotors takes up less space allowing for a narrower center opening on the rim giving you more variety in wheel choices
Old Dec 30, 2004 | 07:41 PM
Trux's Avatar
Trux
Don't bother with lowering the front end, your truck looks just fine the way it is now.
Old Dec 30, 2004 | 09:52 PM
ranger240's Avatar
ranger240
I have photochop slammed many-a-67-72 ford trucks, I think they are sweet when you lay frame. I wouldn't do it personally, but I only have one truck as of yet, and it has to be able to haul stuff and be able to be driven daily. so I am thinking of going with a 4" drop in front 5.5 drop in rear with overload air bags (so I can haul heavy stuff) and some nice 17"-18" halibrands or torque thrust II's.
1970BBF250
13
Apr 16, 2014 08:21 PM
volvo_122s
Jul 17, 2010 10:31 PM
aggie93
Sep 23, 2006 08:50 PM
tude
Apr 1, 2005 10:41 PM
CHARLESFLY
May 6, 2003 07:47 PM
