Instructions for Remote Start
Old Dec 17, 2004 | 05:08 PM
  #46
twoballsleft's Avatar
twoballsleft
Originally Posted by Tim Lamkin
I know I probably should not ask this
...and please no jokes...
what is PW, PL
An your now an Administrator?...I promise I won't laugh...
Old Dec 17, 2004 | 05:30 PM
  #47
TLW's Avatar
TLW
Get the instructions that Hawkins put up and follow them...it isnt to difficult...the door jab boot harness that they are refering to is above the hump for the tranny on the firewall on the inside of the truck....you can make the horn and the cab light connection on that harness too instead of the driver kick panel....I made my key switch connection on the 6 plug connector under the steering colum...the instuction I got from the tech line said not to use that spot , but I already made them there...so if you need help on that connection call the 800# on the box.....any more questions let me know...I'll help if I can. Tim
Old Dec 17, 2004 | 05:36 PM
  #48
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Now be gentle…think of me as a new guy that just joined ….don’t want to run anyone off……
Old Dec 18, 2004 | 12:02 PM
  #49
rotormech's Avatar
rotormech
I had downloaded Hawkin's guide before I deceided to buy the Gold System just to see how hard it would be. So I have before studying it for the past week now.
Old Dec 18, 2004 | 08:07 PM
  #50
rotormech's Avatar
rotormech
Here's a question, where is the location of the red/orange wire on the driver's side kick panel harness? Truck info: 2004 SC Lariet, 6.0L, PL, PW, PM, 4WD, AT.
Old Dec 19, 2004 | 06:49 AM
  #51
t_j82's Avatar
t_j82
what is PW, PL
Tim, Tim, Tim..... Power windows, Power Locks and before you ask PM is Power Mirrors. Kinda like reading the classified ads in the paper.
Old Dec 19, 2004 | 10:42 AM
  #52
IB Tim's Avatar
IB Tim
OK now I know....with my mind "those" I would have never come up with.....tanks...
Old Dec 19, 2004 | 02:36 PM
  #53
t_j82's Avatar
t_j82
That's Ok.... should it concern me what your mind was coming up with?
Old Dec 19, 2004 | 06:31 PM
  #54
ChiefGReid's Avatar
ChiefGReid
Is our Administrator going to have to discipline himself??
Old Dec 20, 2004 | 08:49 AM
  #55
TLW's Avatar
TLW
rotomech, I will look when I get home....but....as I remember all the door lock connections are made on the harness that is on the firewall over the hump for the tranny in the cab...see earlier post in this thread....that wire is in there. Tim
Old Dec 21, 2004 | 10:24 AM
  #56
TLW's Avatar
TLW
rotomech, that wire is in the harness that I descibed on the firewall above the hump inside the cab....just unplug the three harnesses up there and pull the harness down to make the conection.....also there are these harness clips that hold it up out of the way....follow the harness up and pull them off the bolt that they are attached too.....Good luck !!!. Tim
Old Dec 21, 2004 | 01:51 PM
  #57
rotormech's Avatar
rotormech
Thanks TLW. I ended up running all the wires to to the driver's kick panel, except the dome light wire, and the red/orange wire. When I looked at the tranny hump, I didn't see the box you were talking about until I wripped out the driver's seat and stuck my head up into the hole to take a look closer look. It really sits up there. Thanks.
Old Dec 21, 2004 | 02:19 PM
  #58
CampoRoofSuperD's Avatar
CampoRoofSuperD
so what does the truck need to have in order to get this.... This would be very nice for cold weather starts right now and letting warm up... i thought about getting an aftermarket one, but what do you do with the glow plugs....
I believe i have the advanced security group on the new '05 i have the keypad on the door... am i elgible to get fords remote start??
thanks
Kevin
Old Dec 21, 2004 | 03:29 PM
  #59
TLW's Avatar
TLW
Yes you can get a FORD remote starter....unless you are good with electronics I would suggest you let a pro install it for you. Tim
Old Dec 21, 2004 | 07:12 PM
  #60
IB Tim's Avatar
IB Tim
OK ..that is from a dealership only, does it carry a Ford part number?
