Flood damage 7.3L turbo
i would pull the motor so you can pull the rods out and double check them those trucks have a sintered connecting rod and if its just bent a little bit it can break later then it would be a complete disaster with the motor not having many miles on it and worked on wuickly after the water you should be able to reuse most all the motor parts would just need gaskets and probably rods
BdgrDuckHntr
27
11-07-2018 12:36 PM
jackstraw
28
08-15-2017 07:12 PM
ExPACamper
83
05-08-2017 05:30 PM
John Chandler
17
04-15-2017 10:17 PM
FordManiac1242
16
09-26-2012 12:34 PM
