360 to a 460
Old Nov 30, 2004 | 08:37 AM
PoolBoy's Avatar
PoolBoy
360 to a 460
I have a 74 ford f-100 with a 360 and c6 tranny, will a 460 hook right up to the c6?
Old Nov 30, 2004 | 10:34 AM
Mike G's Avatar
Mike G
Nope, the FE and 385 series do not share the same bellhousing bolt pattern.
--Mike
Old Dec 1, 2004 | 09:18 AM
PoolBoy's Avatar
PoolBoy
Is there any adapters I could get to make them match up. or should I just get a different Transmission?
Old Dec 1, 2004 | 09:40 AM
Mike G's Avatar
Mike G
Check with Advance Adapters, I believe. You would probably be best to get a trans to go with the 460, the Fe has been out of production since 1978. I know there are adapters to go to the FE block (for AOD and AEOD), but I do not think they have any to go to the FE trans.
--Mike
Old Dec 1, 2004 | 11:39 AM
rusty70f100's Avatar
rusty70f100
Have you considered rebuilding the 360? When converted to a 390 they can make great power.
Old Dec 1, 2004 | 12:10 PM
PoolBoy's Avatar
PoolBoy
the 360 has a cracked block, so I need a new engine in general, and I happen to have a 460 from a 72 lincoln. I was just wondering if I could just swap that in without too much of a problem
Old Dec 1, 2004 | 12:18 PM
85e150's Avatar
85e150
Lincoln tranny?/////
f25073
Engine Swaps
May 23, 2016 11:33 AM
Gcwstang
Dec 17, 2014 03:35 PM
johncart
40
Sep 29, 2008 12:05 AM
1ole4d
Nov 3, 2006 08:39 AM
Robert R
Oct 18, 2004 10:12 AM
