Took my 87 BII 2.9 EFI ..in for its yearly emission test, has 93k on it.
As the title suggest, it failed…what I am looking for is an 80 or 90% solution…i.e. most of the time it turned out to be the EGR valve, or 80% of the time it is the _____ ……I know this is a bit nebulous to approach something this way…... however it runs great, gets 19.5 in town and 24.5 on the road day after day after…well you get the idea.. I need any and all ideas you guys/gals might have.
And I appreciate any suggestions.
1st thing I would do, especially on an '87 that doesn't have a check engine light, is to pull codes from the computer and see if the computer can see a fault.
Another thought, I don't remember specific numbers, but mine once failed emissions in a similar because the air filter was due to be replaced. Any tune-up like items of that nature that are due to be done may tip the idle HC down for you.
whats your idle speed set it at a 1000 rpm for the test so you pass then reset it
It passed on idle so that won't help.
The catalytic converter burns hydrocarbons that escaped combustion.
When hydrocarbons are too high though, in your test result, CO is almost zero and O2 is low. Maybe there's insufficient oxygen to burn the hydcrocarbons. Is the air filter good? If not that then the cat. may be bad.
Oops, my mistake. I read those numbers the wrong way round.
Was the engine good and hot when it was tested or had it been sitting a while?
