84 Cab Swap
Old Jan 3, 2002 | 09:32 PM
Uniquark's Avatar
Uniquark
Post 84 Cab Swap
I've got a 84 4x4 Ranger with a crushed cab. The frame and motor are real good, so I would like to replace the cab. Does anyone have thoughts about the difficulty of such a project. I have mostly only done engine and mechanical work before, but I did help my father with a bare frame restoration of a 31 Model A.
I'm also looking for sources of information about the cab, what other years would fit, etc. Any help would be appreciated.
Thanks
Old Jan 5, 2002 | 03:15 PM
cubster's Avatar
cubster
84 Cab Swap
You can use any regular/extended cab (depending on your need) from 1982 through 1992. It's alot of work, just dismantling and removing alot of parts, time consuming but relatively simple. Definately better than trashing the whole truck.
Old Jan 5, 2002 | 04:46 PM
Uniquark's Avatar
Uniquark
Post 84 Cab Swap
Thanks for the info cubster. Can you direct me to any sources of information about doing this?
Old Jan 8, 2002 | 05:50 PM
bburgoon
Guest
Posts: n/a
84 Cab Swap
It is a rather time consuming endeavor . As the one guy had said its alot of taking this off, disconnecting this and that. The proper equipment doesn't hurt either. I personally have seen it done once trading out 1-ton cabs. Patience and a cool head will pay off. Good luck
Old Jan 8, 2002 | 09:12 PM
Ken00's Avatar
Ken00
84 Cab Swap
merc2dogs
General Automotive Discussion
Mar 26, 2014 09:29 PM
justshootme84
Nov 6, 2007 02:42 PM
justshootme84
Offroad & 4x4
Sep 19, 2007 11:18 PM
larry57
May 14, 2006 07:35 AM
Truckslayer84
Jan 25, 2002 07:19 PM
