255ci V8?
Old Nov 29, 2004 | 02:43 PM
Mr. Finch's Avatar
Mr. Finch
255ci V8?
Earlier this year I bought a 1981 F100. it is a good truck, but I have some questions I have been trying to answer for several months now. (that is how I found FTE). here are some of my questions.
When I first bought the truck I noticed that the tag said it was a 255ci (4.2l).
The only 4.2l I have heard of was the 256ci v6, but I noticed that this thing had 8 cylinders, so the idea of their being a typo, and the engine realy being a 256was dropped. since then I have determined that the crank was bad; removed the engine and replaced it with a 302fi with rollercams.
If anyone as any info at all I am willing to listen.
My second question that this truck is labeled as a custom f100 explorer, i thought these were known earlier as the rangers, and then as the f100.
Old Nov 29, 2004 | 02:58 PM
7283-F250's Avatar
7283-F250
I bought a parts truck a little over a year ago and it had a 255CI V8. It is a Y block and is most common in the older T-Birds and 60's van's.
The Ranger and Explorer names were a trim level. I have seen many early 80's F100's/F150's with the Explorer labels on them. For example the XLT Ranger trim could be on an F100 or F250 (maybe an F350 but I have not seen any).
Old Nov 29, 2004 | 03:10 PM
V10KLZZ71S's Avatar
V10KLZZ71S
The 255 was a smog era motor that came in Fairmonts,Granada's but i did not know they came in trucks.It was based on the 302,i believe.
Old Nov 29, 2004 | 05:18 PM
Mr. Finch's Avatar
Mr. Finch
255v8?
So far I have heard that it was made in the early 80's as a more fuel efficient 302. it was the same block just smaller bore, and slightly diffrent valves. It was lacking about 10 hp from the 302, and they droped it becouse t-bird fans were not happy with the loss of power. I did not know it was made in any other years except 1980-83.
Old Nov 30, 2004 | 07:39 AM
7283-F250's Avatar
7283-F250
guess I need to look into this more.
Somone somewhere told be it was a Y block. didn't keep the motor so I didn't look into it more.
sorry for the mis-information
I knew someone on here whould know tho.
Sence I joined here I have gained some knowledge and have seen lots of smart ppl.
Old Nov 30, 2004 | 05:45 PM
frohlich's Avatar
frohlich
(from a book)
Specifications are virtually the same as the 302 with exception of the bores. They were reduced to 3.68 (i.e. 3.68 x 3.00) inches and unnecessary cast-iron was removed to make the block even lighter.
Built from 1980 to 1982 MY, cars and trucks.
Old Nov 30, 2004 | 07:13 PM
Cougar64's Avatar
Cougar64
About the only use it has any more is as a boat anchor. It wasn't a bad motor, just lacked power and was a very limited run. I had one in a Capri. Was a reliable motor but it was definately lacking power.
Old Nov 30, 2004 | 07:40 PM
Mr. Finch's Avatar
Mr. Finch
That is the reason I heard it was dropped is becouse it lacked the power. But does it have any value to a collector. In other words, if I decide to fix and sell the truck as an antique would it be worth morewith the original carberated 255, or with an after thought fuel injected 302 (with roller cams)
Old Nov 30, 2004 | 10:45 PM
1982fordf100's Avatar
1982fordf100
I wouldn't think it would have any collector value. I have a 82 F100 with the 300 I6. I believe that you could get the 80-83 F100's with the 3.8 V6, 4.2 V8, 4.9 I6 or the 5.0 V8. The first two engines where horrible attempts at trying to get better gas mileage.
JohnOB
Dec 22, 2006 01:01 PM
55F350Dually
Flathead V8 & Flathead 6
May 20, 2005 05:45 PM
55F350Dually
Apr 2, 2005 02:56 PM
rwall0113
Apr 15, 2004 08:44 AM
rwall0113
3.8 & 4.2L V6
Apr 23, 2003 08:05 AM
