Jets
Old Nov 28, 2004 | 09:53 PM
LedheadELH's Avatar
LedheadELH
Jets
what do the numbers on the jets mean, like if the number is bigger does that mean more flow, and richer?
Old Nov 28, 2004 | 10:16 PM
welldiver's Avatar
welldiver
The larger the # the bigger the hole, the higher the fuel flow
Old Dec 14, 2004 | 11:24 AM
sdkoz's Avatar
sdkoz
So, on a Holley 4160 (O-1850-x), jets listed as 122-66 for the primary are 0.066"? The secondary jet, 134-9, has me confused. Is it in 1/100s (0.09") maybe?
Old Dec 14, 2004 | 11:26 AM
sdkoz's Avatar
sdkoz
Also, to go from elevation (Denver) to sea level, would you increase jet size or decrease? My 77 F-150, 400, is running pretty rich at 300 ft.
Old Dec 16, 2004 | 07:19 AM
lee's Avatar
lee
sdkoz,
The 1850 carb does not have jets in the secondaries. It has a metering plate with holes drilled into it that serve the same purpose as jets. 134-9 is the number of the plate.
The air at sea level is "thicker" than the air at the Mile high city, so at sea level you would run leaner and your carb would require jetting up to compensate. Now this does not go along with you saying your running rich at 300 ft. You should be running lean. Hum?
Lee
Old Dec 16, 2004 | 02:18 PM
sdkoz's Avatar
sdkoz
That was one of those questions that after you ask, you go, "Duh." If running rich (and nothing else is messed up), you'd jet down. It was running rich in Denver (and has been for some time even before the carb needed work) and the carb needed rebuilding, which I just finished. I dropped down 3 jet sizes on the primary (66 to 63). Don't have a feel for whether that is too much so I'll find out tonight if I am able to work on it. If so, I'll try again.
Rick_Fury
Dec 14, 2011 07:52 PM
Bruker
Jul 23, 2007 08:14 AM
GeneStoner
Dec 12, 2004 09:10 PM
200000+F150
Jul 2, 2003 06:15 AM
lilpig88
Jun 8, 2003 11:59 PM
