I've done a search and have also posted this question before(about a year ago) but I am hoping someone new or someone knows if there is a benifit to removing the muffler on a 7.3 PSD. The truck is a 03 550 with about 50,000 miles on it, bone stock except for the ebpv brake mod. Also it has a catalytic converter. Does removing the muffler add alot of noise even if the cat is retained? I know I could add alot of mods to this truck, but I dont want to put much money into it-just trying to do the cheap stuff! Hope someone can help.
The biggest benefit of modifying the exhaust is to reduce egt's by allowing exhaust gasses to flow more freely. By removing the muffler only, you probably won't notice much more than a change in exhaust tone. It won't be loud, since most of the noise is reduced at the turbo. You'll receive more of a benefit if you upgrade to a 4" system, especially if you decide to add a chip or programmer.
BTW, some of the 4" exhaust systems are available with a muffler delete pipe. There are a few on this forum who are running a setup like that.
On 99+ trucks the muffler is rather restrictive. 94-97 the stock muffler was a real nice straight through design, very low restriction.
Exactly. As far as reasons to remove the muffler, lower EGTs is probably the best one. If you leave the cat in place you will hardly notice any difference at all in sound. My truck lost it's cat and muffler awhile ago. I love the sound and the lower temps, but the sound may be to much for some. With a 550 it would depend a lot on what type of bed is on the truck, as that could greatly effect how the truck sounds in the cab. Mine with the windows rolled up just cruising sounds almost stock, now WOT is a different story. I am still driving around with my windows down to listen to my exhaust and its been getting pretty chilly here.
I lost my cat and muffler, have been running it that way for 6+ months and like it alot. I also put a 4" SS turn down tip on it which made it quieter from the cab. It directed the noise more towards the ground kind of deadening it. Worth a shot at trying.
1965 doing what you asked will help your EGT's, and flow much better. The stock down pipe SUCKS for flow, it is smashed to make clearance. But it is illegal to remove the cat.
Only if you get caught!
Know the emission laws in your state, they vary from state to state, testing the trucks and the such. If you do get tested where you are at, I'd be very weary of cutting the cat. If you don't get tested, then you can. I took the gamble and cut mine out, but we don't do any testing here in Iowa like they do other states, so far I've been ok!
farmbOy I agree with you as I have done the same. But it would be a diservice not to inform someone of the risks. As far as I know the emission laws are federal so they should not change much except for the state of CA.
The method for testing diesels varies from state to state, and from county to county within certain states. Some places will conduct a visual inspection of the rig, looking for a catalytic convertor, among other things. Other places will conduct some sort of a running test on the truck. Here in Seattle, all they're looking for is measurable smoke at WOT. In other places, the test is a lot more comprehensive. My daughter lives 20 miles south in another county, and there's no testing at all.
Find out what's required in your location before acting.
In Ohio, (southwest anyway), they test for opacity, which is a fancy way to say they test for smoke in the exhaust. Anywhere they do testing, I would not remove the cat. I have heard you can gut it though. I don't know if I would risk that either!
