oil weight?
Old Nov 27, 2004 | 08:57 PM
sbe12g's Avatar
sbe12g
oil weight?
what weight oil would you recomend for a 460 with 156,000 miles? doesnt smoke either.
Old Nov 29, 2004 | 09:27 AM
wizzard351's Avatar
wizzard351
i use castol 20 50 in everything from the lawn mower to my pick-up year round
Old Nov 29, 2004 | 06:47 PM
jim henderson's Avatar
jim henderson
If your pressure is good, you don't burn oil etc, I would use what the manual says, probably 5W30 to 15W40. If you burn oil or have low pressure I might go to 20W50 except in freezing conditions.
Good Luck,
Jim Henderson
Old Dec 3, 2004 | 10:11 PM
BSHORT's Avatar
BSHORT
Top Answer: 5
I Use Delo 15/40. Works Fine, No Problems.
Old Dec 4, 2004 | 01:25 PM
Brad Johnson's Avatar
Brad Johnson
In general, the lightest oil you can use and still maintain oil pressure or not have oil consumption problems is the way to go. Anything heavier is just lost HP, and anything lighter has you running the risk of wear issues.
Brad
Old Dec 4, 2004 | 02:24 PM
Bear 45/70's Avatar
Bear 45/70
I like 10-40 in the winter and 20-50 in the summer. Mainly because I have the camper on the truck and tow a trailer(either the flat bed dually with quads or the boat) in the summer. Right after hunting season I switch to the 10-40. Oh yeah, I happen to like NAPA's house brand oil. I found out the Citco makes it for them and it is reasonably priced.
Old Dec 5, 2004 | 08:47 AM
Bill_Beyer's Avatar
Bill_Beyer
Multi-vis oils were originally developed to eliminate the need to change the oil in vehicles based on the ambient temperature outside, i.e. changing from 30 weight in the summer to 10 weight in the winter, hence the W in 10W40. The oil manufacturers developed multi-vis oils by adding synthetic polymers to a 10 weight oil base which prevented it from thinning out more than straight 40 weight would at the same temp. IOW it's still 10 weight oil, it just doesn't get as thin as straight 10 weight oil would when it gets hot. The downside is that these polymers tend to break down, burn and form sticky deposits in the oiling system, commonly known as "sludge". The wider the spread, the more polymers are needed. More polymers added means more deposits even with the addition of detergents.
Ideally as Brad Johson said, the lightest oil you can get away with and still maintain the protective properties of the oil is the best idea. But you also need to be cognizant of the "sludge factor". For this reason I stay away from 10W40 and 20W50 and stick with 10W30 or 15W40 in higher mileage engines. In a brand new or freshly rebuilt & broken in engine I use 5W30 or 10W30.
ford390gashog
105
Dec 4, 2015 02:01 PM
ken1960
6.7L Power Stroke Diesel
27
Dec 6, 2013 01:12 PM
midsouth
May 29, 2013 03:01 PM
texasft
1966 - 1977 Early Broncos
Sep 8, 2011 12:46 AM
broncman
Jan 31, 2006 07:10 PM
