WHAT WEIGHT OIL ARE YOU RUNNING IN THE FE's - Ford Truck Enthusiasts Forums
View Poll Results: WEIGHT OIL ARE YOU RUNNING IN THE FE's
5w20
2.12%
5w30
5.51%
5w40
2.54%
10w30
27.54%
10w40
21.19%
15w40
11.86%
15w50
2.12%
20w50
16.10%
30w
10.17%
50w
0.85%
Voters: 236. You may not vote on this poll
Old 10-29-2004, 03:27 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
WEIGHT OIL ARE YOU RUNNING IN THE FE's.
Old 10-29-2004, 04:17 PM
gtex's Avatar
gtex
gtex is offline
gtex is gaining momentum as a positive member of FTE.
Castrol GT+ 20w50
I can't even tell you why. but I've run it in just about everything I've touched in the last 15 years. (excluding my 2002 SS, it's on a synthetic diet).
Of course, I live in Central Texas...
Old 10-29-2004, 04:47 PM
77fordguy
77fordguy is offline
77fordguy is new and has a neutral reputation at this point.
10w40 and I live in Pittsburgh (the cheapest brand I can find)
Old 10-29-2004, 04:54 PM
Scouder's Avatar
Scouder
Scouder is offline
Scouder is gaining momentum as a positive member of FTE.Scouder is gaining momentum as a positive member of FTE.
Castrol 20-50. Going lighter in the winter. Probably a 10-30 or so.
-Scouder
Old 10-29-2004, 05:57 PM
Chas1234
Chas1234 is offline
Chas1234 is starting off with a positive reputation.
10w40 I am in southeastern CT and and although it doesnt get that cold here it does get cold enough and hot in the summer .
I get 55 PSI hot running on the highway and 35 psi hot at idle .
USE THE FORD OIL FILTER !!!!!!!
Old 10-29-2004, 06:43 PM
debestuss
debestuss is offline
debestuss is starting off with a positive reputation.
15W40 because Rusty said I should. Haven't put the motor back together again to see what oil pressure I'll have. FL1A oil filter.
Old 10-29-2004, 09:11 PM
TheImpaler
TheImpaler is offline
TheImpaler is starting off with a positive reputation.
10w40. Not sure why. : )
From the poll, though, I think I'll be using 20w50 this time around.
We're finally cooling off here in AZ - what would be good for the 40-70degree range?
-Patrick
Old 10-29-2004, 09:41 PM
rusty70f100
rusty70f100 is offline
rusty70f100 is gaining momentum as a positive member of FTE.rusty70f100 is gaining momentum as a positive member of FTE.
I'm using 10w30 in the 360 right now, but the new 390 will see nothing but 5w40 Shell Rotella T synthetic.
Old 10-29-2004, 10:20 PM
ford390gashog
would 5w30 work ok in a 390 or should i use 10w30
Old 10-29-2004, 10:23 PM
rusty70f100
I looked in your public profile, and in California I think 10w30 would be better, due to fewer viscosity index improvers.
Old 10-29-2004, 11:28 PM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
10w40 in winter, 20w50 in summer, only in my FE 390 - NOT my modulars
Get around 80 PSI cold, whether I use 10w40 or 20w50, but get another 5lbs at hot idle with the 20w50, I usually get at least 25psi HOT HOT HOT with 10w40.
Old 10-30-2004, 12:12 AM
Randyb12
Randyb12 is offline
Randyb12 is new and has a neutral reputation at this point.
Castrol 20-50 because that is what my machinist told me to run with the clearances I have in my bottom end.
Old 10-30-2004, 02:32 AM
FORD352V8
FORD352V8 is offline
FORD352V8 is starting off with a positive reputation.
10-30 in the winter and 15-40 in the summer. Mystic oil for me.
Old 10-30-2004, 10:50 AM
JonnyB69
JonnyB69 is offline
JonnyB69 is starting off with a positive reputation.
When I rebuilt my FE, a mechanic friend of mine told me Castrol 10w-30 or 10w-40...said he'd never had an engine fail in cam break-in or otherwise with it. Doesn't get too cold here in the winter though.
Old 10-31-2004, 12:42 AM
Hypoid's Avatar
Hypoid
Hypoid is offline
Hypoid has a good reputation on FTE.Hypoid has a good reputation on FTE.
10w40 Castrol. Flows when it's c-c-cold, doesn't thin as bad as others when it's hot: brand preference based on unscientific comparisons in an air cooled motorcycle engine run in 90 to 100 degree ambient.
When oil can get past the rings, I'll switch to synthetic for annual emmision testing.
Quick Reply: WHAT WEIGHT OIL ARE YOU RUNNING IN THE FE's
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
