taillight problems
Old Nov 27, 2004 | 08:55 PM
muffin's Avatar
muffin
taillight problems
i've got a troubling issue if anyone can help me I would appreciate it.
I have a 1992 ranger. The turn signals work, the stop lights work, the backup lights work but the rear running lights won't come on. I've checked the grounds, the sockets, the fuses, & the bulbs. I'm out of ideas. Can anyone help?
please e-mail me back at muffin092570@aol.com
Old Nov 27, 2004 | 09:37 PM
Steina's Avatar
Steina
CO River Rat
Have you checked the socket pin for voltage?
Steve
Old Nov 28, 2004 | 01:04 PM
Franklin2's Avatar
Franklin2
Do the rear license plate lights work?
Old Nov 29, 2004 | 05:10 AM
muffin's Avatar
muffin
Yes. The license plate lights do work. I had to replace both bulbs and one of those sockets also, but they are on now. I disconnected the wiring harness at its connection in the engine compartment and using a DC power supply I have, I powered up all the pins individually and everything seemed to work. I seem to be leaning towards the switch being bad but I don't understand why the fronts would work but not the rears. Does the switch seem to be a likely problem?
Old Nov 29, 2004 | 10:56 AM
Franklin2's Avatar
Franklin2
The rear license plate lights use the same wiring as the rear taillights. There should be a splice back there somewhere to split the wiring from the taillights to the license plate lights.
Look at this diagram. See how the brown wire leaves the headlight switch, and feeds the license plate lights and the rear taillights?
http://www.autozone.com/images/cds/g...3d800ba9d3.gif
Old Nov 29, 2004 | 11:50 AM
muffin's Avatar
muffin
Thank you for all your time and efforts. The wiring diagram should prove helpful. I won't be fumbling around in the dark now. I hope this will help solve my issue.
GaryKip
Ford Truck Parts for Sale
Jul 14, 2016 03:02 AM
jgavac
Jul 17, 2012 05:31 AM
b_2187
General Automotive Discussion
May 21, 2006 07:12 AM
mm9093
1978 - 1996 Big Bronco
Jul 2, 2004 02:29 PM
415C.ci. GUY
Modular V10 (6.8l)
May 22, 2004 10:44 PM
