Fuel Pump Volts
Old Nov 28, 2004 | 04:47 PM
Lucky Charms's Avatar
Lucky Charms
Question Fuel Pump Volts
How many Volts should be going to both fuel pumps? This is for 87 ranger 2.9L
Matt
Old Nov 28, 2004 | 09:01 PM
Franklin2's Avatar
Franklin2
12v, or whatever the battery voltage is.
Old Nov 29, 2004 | 11:14 AM
Lucky Charms
Thumbs down Fuel & Volts Going CRAZY!
Ok
No volts at either pump When I first started I could hear the pumps engauge.What am I doing wrong???No power @ the inertia wires & yes volts @ the relays . 1adam12 we have a man down!Send back up units!!
Matt
Old Nov 29, 2004 | 01:51 PM
Franklin2's Avatar
Franklin2
Look in the middle left of this diagram.
http://www.autozone.com/images/cds/g...3d800f9476.gif
You will see the fuel pump relay. See if you have voltage across the coil. You should have 12 volts between the red and tan/lightgreen wires. If you don't then you might have a problem with the ignition system. If the computer does not receive a pulse output from the dist module, then it assumes the engine is not running and will shut the fuel pump relay off.
