An Electrical Query
Old Nov 27, 2004 | 12:19 PM
heavnbound's Avatar
heavnbound
Question An Electrical Query
This may sound like a simple question, but I am considering going to a larger alternator to run additional lights, and my question is if I get too large an alternator, will it harm any of the components of the vehicle such as computer gizmos or power features like power windows, doors, keyless entry, etc.
My 2004 Excursion has either a 115 or 130 amp alternator and I want to run some LightForce lights so I may go to a bigger output alternator. But I don't want to burn anything up.
Where does excess electricity the alternator produces go?
Old Nov 27, 2004 | 03:54 PM
Franklin2's Avatar
Franklin2
The alternator never produces excess electricity, unless something is wrong with it. It has a regulator, either built-in, or seperately mounted. The regulator monitors the truck's electrical system voltage, and tries to keep it steady. The regulator varies the voltage to the field, which varies it's magnetic strength. More or less magnetism in the alt means more or less output. You should be ok, but I would upgrade the output wire from your new alternator to a bigger size, and also you might possibly put another small fuse panel under the hood to feed your lighting relays. Your lighting should come with relays to switch the heavy load of the lights.
Old Nov 27, 2004 | 09:58 PM
heavnbound's Avatar
heavnbound
Thumbs up
Thanks for the info Franklin2, It's put me more at ease about the bigger alternator. The install will be professionally done so I'm not worried about the wiring, relays, etc. Just didn't want to mess up anything else.
Still not sure an alternator upgrade is going to be necessary but if so, then your info will make it a lot less confusing.
LipschitzWrath
22
Aug 14, 2017 05:22 AM
72camperspecial
May 28, 2013 09:12 PM
brandon.edwards
Mar 14, 2013 09:23 AM
bly8397
Dec 27, 2012 10:41 AM
mrskat41
Jul 6, 2003 08:14 PM
