Mystery part... Please help identify
Old Dec 20, 2004 | 07:45 AM
CarterCrew's Avatar
CarterCrew
A/C is not only for the summer. It is also a must for defrost in humid areas. I have a 92 and a 93 F-350, and when you switch to defrost the a/c runs. I know it makes a difference because the 92's system quit at the end of the summer, and the defrost doesn't work near as good as the 93's. One more thing on the list to fix. By the way, along with the nut/bolt the holds the clutch plate on the compressor there are also small shims ( they look like washers). Their purpose is to space the clutch out far enough so it won't drag when not engaged. You don't want too many shims though, or the gap may be too much for the clutch to pull in properly.
Old Dec 20, 2004 | 09:15 PM
Dieseldan7.3's Avatar
Dieseldan7.3
Probably wont be fixing it anytime soon, just wanted an idea of cost. I have better areas of my truck to be spending money on. The window works great at 70 mph.
sammie0126
Aug 7, 2013 09:15 PM
trevstaff
Nov 27, 2010 10:59 AM
dadstruck
58
May 6, 2008 08:56 PM
61 uni
Jul 15, 2004 07:37 AM
