antilock brakes
Old Feb 8, 2002 | 10:26 PM
zootue's Avatar
zootue
antilock brakes
I have a 93 Ranger and the antilock light is on. I had to pull the fuse so the truck would stop when I wanted it to. What's wrong? The pads and shoes are good and the master is full. No air in the lines either. Thanks for your help.
Old Feb 8, 2002 | 10:34 PM
Ken00's Avatar
Ken00
antilock brakes
First make sure the master cylinder is full, the float is not sticking, the back brakes are adjusted correctly, the connection to the RABS valve and VSS is good. If everything is OK the you need to pull the code. Locate the test connector under the drivers dash just above the parking brake, it has a blk/org wire, see if it has a red wire connected to it. I can give you further instructions and the pinpoint tests for the code. Is the red parking brake light on also? Do both lights turn on and off when you first go to start it, the self test.
Old Feb 8, 2002 | 10:42 PM
wptski's Avatar
wptski
antilock brakes
Rooster1982
Oct 12, 2013 08:06 AM
liberty2701
13
Aug 12, 2011 07:33 AM
DBANDGB
Nov 11, 2006 08:03 PM
kameronth
1978 - 1996 Big Bronco
Feb 7, 2004 12:57 AM
rickm5
Aerostar
Jun 7, 2002 11:42 AM
