Bulletproof TTB conversion?!?
At the moment I have a 90 2wd f-150 with a 300/6 and a 5-speed (not sure what kind), I have a 6" rough country lift, with 3/4 ton dually leaf springs in the rear, on top of that I have a 2" body lift and 31x10.50's.... at this point my truck looks like a 4x4 (more people that I can count on both my hands have asked me)... What I really want is the serious off-road capabilities, but not spend the money on a solid axle conversion (spent too much on the lift kit to convert now), so I intend on putting together a TTB 4x4 drivetrain out of the best parts available in f-150's that will work together without too much serious fabrication.... before I put the lift on I was going to put my cab, bed and motor on a 79 frame with a solid axle front end, but I turned away from that because it seems like a needles hassle....
I'm fully capable of doing fabrication and higher level mechanic work, so I'm not going to get too scared away from doing this... I want a manual shifting transfer case that will work with an older 4-speed with granny gear transmission (I will try to get info on the tranny later, all I know is that its a "bulldog" tranny and it is very tall), and I want a front TTB axle with manual locking hubs and maybe a 4.10 gear ratio.... In the near future I'm going to put 35x13.50's on my truck, so take that into consideration....
What I'm basicly asking for is opinions on components that would able to handle more of a serious off-road situation, and information as far as what year and model trucks it was available in... for all of you that have TTB 4x4 or are converting it I want to know what things you wish you would have done and should have done, and what parts you wish you would have gotten instead.... I hope I didnt write too much of a novel, but I hope I got my point accross somewhat... Btw this is one of the most informative forums I've been on in a long while, lol I'm a converted chevy driver, so please dont hold that against me, I didnt know what a truck was until I got my 150....
You currently have a crappy mazda 5speed tranny. You want to get either a ZF5, NP435, or a T18. Any tcase Ford produced b4 '96 or '97 should fit fine.
All the TTB stuff from a 4x4 truck will bolt up.
I can buy an entire 79 frame with the solid axle front, rear axle, transfer case, and transmission, with all the suspension parts for $600... the main reason I'm so reluctant is because I just put the lift on yesterday, and I know there is no way in hell that I'd be able to get all my money back..... I just want to do a TTB front.... there are plenty of donor trucks and I know how to make some deals.....
I appreciate your opinion but I'd rather just go TTB, I just dont know if there were better front axles in different years and all that, thats basicly the info I'm looking for....
I understand what your are saying about not wanting to go with the sas, but my personal preference would be to go that way now, and save the money cause if you stay around here long we will corrupt you, and you'll be needing more, and more.
SAS! SAS! SAS!
I want a set-up with 35" tires that can handle it without major problems..... and I think my decision will be swayed before its all over with because I'm already contemplating a sas.... I want to keep a 5 lug and I want to keep it practical as a DD, I dont mean small tires and high gear ratios, I mean being able to get a minimum of 10 mpg and atleast being able to go 70 mph without having my engine revv too high... lol I dont mind having to take a running jump to get into my truck, and I dont mind listening to the sweet melody of the tire humming..... but damn I'm not trying to get too far into this, either way I only have a 300/6, so I cant get too carzy (please no one suggest a motor swap, this baby aint coming out).....
but the problem lies with the fact that there is no NV4500 ment to go into a ford, you have to get a Dodge version and get a conversion plate and a fewe other items to make it work, since you have a F150, id go with the ZF tranny, any T-case from 78-96 will work, but youd be better off to go with the NP205 for strength, the lowrange sucks on it, but otherwise id just go with the BW1356 for its .7 higher lowrange.
i really think youd be happy with the TTB setup, if its open diff, 35s would be no problem, if you lock it, carry some spare shafts. no big deal. the nice thing about the TTB is that in your case, its a durect boltup to what you already have! just take out the 2wd stuff and bolt the TTb in there! where are you located at? if you are anywhere close to snohomish Wa id sell you all the TTB parts off of my Bko, i removed all of it in favor of a D60 leafspring setup. it will need new U-joints, balljoints and tierods, but the spindle hubs and bearings where taken care of. lemme know, mybe we could work somthin out!
I understand why everyone is trying to convince me to go to a sas, but right now I think I will just focus on TTB with this rig and later on build a true mud stomper, with a solid front axle and a motor combination worthy to sling mud.... my friend has a 79 4x with 33's and a 429 cobra jet, he gave $800 for it, and quite frankly that would seem better for serious off-road... one good thing about this forum I realized that with TTB its not gonna be as capable of what I want, but for a DD that will see some weekend fun it will be more than plenty, I just have to look around for another deal like that 79 my buddy got....
I have my eyes on a donor truck that hasnt moved an inch in a year or two, it bellongs to the NC road department and I think I can work something out with them... I dont know exactly what year it is, but I know everything is exactly like mine, 300/6, 5-speed, so that should make for an easy swap....
the main reason I want 4x4 is because another friend of mine has a 4x4 s-10 and it really irritates me that he can go places that I can in 4wd, but cant move an inch in 2wd, and I can go all these places in 2wd but he still talks poo-poo like his truck is the hottest thing around, we are talking about having a pull-off bumper to bumper and I have a feeling even with him in 4wd I'll pull him around....
I dont know right now I'm getting alot of glorification for having the most capable, mean looking, and tallest 2wd truck in the area, but right now more than being "different" I want to have more fun..... I'll have to get some action shots to show that I can make my 2wd do things most cheby owners are in envy of.....
How much work is invovled in swapping that axle into my rig??? please be somewhat descriptive I want to weigh my options...
i totally agree with everyone here about doing a SAS b/c you only have to spend the money once. you can't help it you jumped the gun and bought a lift before the truck was even 4x4! BUT a ttb can be pretty dern strong and you will need to learn to keep your foot off the mat...although with a 300-I6 i seriously doubt you will break it with 35's!
i have a D50 ttb axle complete from hub to hub including shocks and leafs. i will sell it cause all it is doing is getting ion my way. if you are interested in the D50 lemme know cause i wheel at Tellico quite often as we have about 50 acres up there and are building.
-cutts-
Yeah the TTB's can handle the mud and dune hopping, but in the rocks the will do diddly squat cause of their lever type design. If you could get that guy down under 500 on that 79 frame, that would be the way to go cause you will get a stronger tanny and t-case, and finding all the ttb parts will cost about the same, but you won't get the better t-case and tranny.
