Bronco II Ford Bronco II
89 BII Temp. sending switch color code????
Old Nov 24, 2004 | 05:54 PM
threespeed's Avatar
threespeed
What's up with the different color of the insulator on the temp. sending switch. I went to Advance Auto to get a temp. switch for my 89BII and the guy asks me what color the insulator is. He said they listed 3 different colors for this truck, green, black or white. Does anyone know which one it is? Auto Zone offers only a black one.
Allen
Old Nov 24, 2004 | 06:34 PM
87 XLT's Avatar
87 XLT
Are you talking about the single wire temp gauge sending unit? Or the 2 wire engine coolant temp sensor? I have no idea what the guy is talking about.
Old Nov 24, 2004 | 08:29 PM
threespeed's Avatar
threespeed
single wire temp switch
Old Nov 24, 2004 | 11:56 PM
87 XLT's Avatar
87 XLT
Calling it a switch might be confusing them. Tell them you need a temp gauge sending unit. Why are you wanting to replace it? Flaky temp gauge?
Old Nov 24, 2004 | 11:58 PM
87 XLT's Avatar
87 XLT
Calling it a switch might be confusing them. Tell them you need a temp gauge sending unit. Why are you wanting to replace it? Temp gauge bouncing around?
Old Nov 25, 2004 | 12:26 AM
threespeed's Avatar
threespeed
The temp. guage has stopped working. The truck ran hot and cracked the heads. I replaced the heads and now the temp. guage does not work. I grounded the lead and the guage went to hot so I am replacing the temp. sender. The box says "temp. sending switch" so that is why I called it a switch. But back to my question, there are 3 sending units listed for my 89 BII. One has a green insulator, one has a black insulator and one has a white insulator. I can't tell for sure what is on my truck. The guy at Advance Auto could not tell me what the difference between these 3 sending units are. I thought you guys might know.
Old Nov 25, 2004 | 03:28 AM
87 XLT's Avatar
87 XLT
Try calling a Ford dealer parts department & see if they know what this nonsense is about. I took a look at the sender on my 87 2.9 & the only color I see on it is a black rubber seal. I've never had this problem when buying a temp sender for my 2.9 or 3.0.
Old Nov 25, 2004 | 08:34 AM
threespeed's Avatar
threespeed
The guy showed me a black one and a green one but said he would have to order the white one.
Old Nov 30, 2004 | 04:35 PM
threespeed's Avatar
threespeed
Well I tried the black temp.sender and the green sender and neither one worked with my guage so now I have a red one that is the replacement for the white one that in on my truck now. Wow this is confusing!!!!!
Allen
Old Dec 1, 2004 | 03:47 AM
87 XLT's Avatar
87 XLT
Napa part number TS-6628
Old Dec 1, 2004 | 05:27 AM
turborich's Avatar
turborich
do yourself a favor and put some manual gauges on your truck. the factory ones are screwy anyways. my oil presure gauge sometimes read normal and sometimes low, i replaced the sending unit and still the same thing. i put a maual temp, oil and amp gauge in and now i know its right. and the oil presure is constant. in the past the temp gauge read normal and the old motor cracked a head due to overheating. the stock gauges are trash. you can pick up a tripple gauge set for $20 and up
finallyo3gt
18
Jul 16, 2016 08:47 PM
ABF PSD
Feb 9, 2012 09:26 PM
DFWBII
Bronco II
16
Jan 29, 2011 11:32 PM
K8's Ford
13
Oct 19, 2010 05:39 PM
truvoice1
Bronco II
Jul 3, 2009 09:56 AM
