Offroad & 4x4
Snow Commander???
Old Nov 24, 2004 | 12:34 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Snow Commander???
heres one for Ya'll with the history books to look up...a couple years ago my sisters father gave me a 1978 4x4 F-250 "Snow Commander" its full time 4wheel and has a 351m (i added a 500cfm 2bbl street avenger holley) and a c4 i beleive...im trying to find out if what he told me is true about it being a 1ton truck under the F-250 logo...it supposedly came factory from ontario with a plow on it...i was told it was a Penn-DOT truck back in its prime....it runs like a champ and u cant get it stuck with the 35" BF goodrich mud terrains i put on it....i love this ugly truck..i got the number off the front diff. the driver door and door frame....here they are....
front axel code: 3.54 D8TA ZE
610023-1
Driver door tag: X25SKO23852
155 SM X259 ABM G37E
08100 1977 11
Driver door frame: F26HCAG4113 9-77
GVWR 8100lbs
Front GAWR 4500lbs
Rear GAWR 5300lbs
i hope this helps...i double checked and all the numbers are correct...
any honest info is appreciated.....thanx....
BTW: im trying to get my pics on my puter...hopfully it will be soon.
SwOkcOffRoader
Old Nov 24, 2004 | 12:44 PM
ivanribic's Avatar
ivanribic
That's what my truck was. They generally call it a "Snow Fighter. You should have a Dana 60 front axle. I'll give you $50 for it. Sounds like a nice truck!
Old Nov 24, 2004 | 12:45 PM
jesse460's Avatar
jesse460
I have never heard of a snow comander, Is it the same as a snow fighter? they have dana 60s front and rear EDIT Ivan types to fast beat me to it
Old Nov 24, 2004 | 12:46 PM
SwOkcOffRoader
snow fighter could be it...my memory isnt what it used to be...
are these trucks rare???
Old Nov 24, 2004 | 01:09 PM
monsterbaby's Avatar
monsterbaby
they aren't the most common but I wouldn't call them rare. now if it actually has a C4 in it THAT I would call rare more likely it has a C6 tranny though
Old Nov 24, 2004 | 02:24 PM
Momudder720's Avatar
Momudder720
Not really a 1-ton truck. The snow fighter package included the D60 front axle and probably a stiffer suspension. Maybe a heavy 3/4-ton, but not a 1-ton truck.
Old Nov 24, 2004 | 04:23 PM
SwOkcOffRoader
i asked about 1ton because i replaced the axel knuckles and ujoints and the ones Napa gave me for a F-250 were too small...i had to use F-350 ones.and according to the haynes manual and tag on the drivers door..the tranny code is G and that shows a C4 in my haynes book....
Old Nov 24, 2004 | 05:11 PM
monsterbaby
proper way to identify the trans is looking at the pan, hayes manuels have some notorious misprints that can almost be funny I don't have a book to decode the door tags but that would make it a big block bellhousing C4, and that is just not something ford did in trucks, (not even sure they ever put the C4 behind the big blocks in anything but I won't say never with Ford)
Old Nov 24, 2004 | 05:26 PM
ivanribic's Avatar
ivanribic
That's because the front axle is the one used in the 1 ton trucks. However your rear axle is probably also a Dana 60 which is the 3/4 ton rear axle. 1 tons generally had a D60 front and a D70 rear. I might be wrong here but it seems to me that the Snow Fighters used the same front leaf springs as the regular F250's. If you do a search in the 73-79 forum you'll find a TON of info on them. Just remember that to make the search find all the words you have to use pluses so go +snow +fighter and you'll find some detailed threads.
Old Nov 24, 2004 | 09:32 PM
SwOkcOffRoader
well....maybe im doin it wrong but i searched like u said +snow+fighter and only came up with the threads i posted....ill try again later..i thank everyone for their input, i was wondering did i post in the right thread to maybe find out more about my truck through useing the numbercodes above??or does anyone know of a way to find out the history on a vehicle this old?? Thanx again everyone........
SwOkcOffRoader
1976 F-150 460 780cfm 4bbl holley "Hot Rod"
1978 F-250 Snow Fighter D60's Front and Rear 35" BFG Mud terrains
Full time 4x4 351m400 500cfm 2bbl holley street avenger "Big Daddy"
1978 B-700 Bus 389 4bbl holley 10 speed "Yes its a Ford too!!"
Old Nov 24, 2004 | 09:36 PM
SoCalDesertRider's Avatar
SoCalDesertRider
To identify the tranny, count the pan bolts. The C6 has 17 of them and pan has a big notch in one corner. The C4 has a square pan with 11 bolts.
Old Nov 24, 2004 | 09:40 PM
ivanribic's Avatar
ivanribic
She's been around . . . do you really want to know? I don't know where the vin decoders are but they'll have them in the 73-79 forum. Btw, you searched the offroad forum only, not the 73-79 forum. Go there and search in the upper right hand corner under "Search this forum" and you'll come up with plenty. Try this link, though I'm not sure if it'll work: https://www.ford-trucks.com/forums/s...earchid=396763 There's a lot more specific info in that forum about the details of the old trucks whereas this forum is more about the 4x4 aspects of all years. Not that you can't ask questions here, it just might not provide you with the best answers.
Old Nov 24, 2004 | 11:00 PM
fishmanndotcom's Avatar
fishmanndotcom
need some VIN decoders? check out a previous post i put up a while back
http://fordtrucks.com/forums/showthr...ht=vin+decoder+
-cutts-
Old Nov 25, 2004 | 12:12 AM
SwOkcOffRoader
thanks fellas.......ill check em out....
Old Nov 25, 2004 | 12:52 AM
SwOkcOffRoader
Found a few good threads...still reading through more...BTW i was wrong about the book i looked up my tranny code in...its a chilton not a haynes manual.....of course chilton's could be wrong as well........but i sure like thier wiring diagrams though!!!
