Offroad & 4x4
Snow Commander???
Old Nov 25, 2004 | 02:35 AM
f250rangerexplorer's Avatar
f250rangerexplorer
why is the GVW lower than mine. his is 8100 and mine is 8400. why is this? my trans code i G also and i gotta C6. I'd like to know why this code is C4 in the decoders but not the truck? why did for use this code for both trans?
-Aaron
Old Nov 25, 2004 | 11:04 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
Great question hope fully someone finds out....if u do before me let me know...and ill do the same for u.........
Old Nov 25, 2004 | 04:21 PM
f250rangerexplorer
alright thanks i'll do the same. i've been thinking and can't understand.
-Aaron
Old Nov 26, 2004 | 07:17 PM
SwOkcOffRoader
ok i looked and i definitly have a C6, my chilton was wrong, surprise surprise, can anyone tell me what Tcase is in my truck, its a full time 4x4, the selector has 5 settings, lock-high-neutral-low-lock, what do these settings mean, my shifter linkage is broke so i can only get low or high with a crow bar, i like what u have ivanribic, with the dual tcase shifters, is that aftermarket or homemade??please help, i want to rebuild this truck right, and i want to use the original Tcase but im getting a loud thumping noise under power, especially in low range, is this fixable??
Old Nov 26, 2004 | 08:21 PM
f250rangerexplorer
you have a New Process 203 (NP203). ivan's modifacation is both home made and factory. i believe he got the shifters from a Dana 300 and the transfercase he has is a NP205. He'll tell you the rest.
-Aaron
Old Nov 26, 2004 | 10:02 PM
ivanribic's Avatar
ivanribic
My shifters were from JKW, not a D300 but they are similar. You could also make your own quite easily. If I had understood the whole setup 100% I would have just made them but since I didn't and I'm lazy I paid $100 to have someone else do it. You cannot twinstick a 203 as it is chain driven. I responded to your post in the tranny forum regarding the noises you're having. I don't think it's t-case related, I think it's binding in the u-joints when you make really tight turns. Let us know if this noise is coming from the front end or if you know that it's specifically coming from the t-case.
I would suggest that you keep an eye out for a 205 and swap that in so you don't have to worry about breaking or stretching chains. Plus you can twinstick it before you throw it in the truck. It will use the same adapter to mount to the C-6. But if the 203 is working properly that's not high priority right now.
PS If you click "Club FTE Member" by my user name it will take you to my site where I outline what's involved in twin sticking a 205.
Old Nov 27, 2004 | 01:55 AM
SwOkcOffRoader
NP 203 huh?? i was hopin it was a 205, so im gonna change it anyways now....i asked the previous owner about the noise because i too thought it was the ujoints but he replaced the ones in the axels with F-350 joints and i changed the driveshaft joints as well......it only makes the noise turning when i use a crow bar and shift to the lock position...but it does it most under power like when im in a deep hole or climbing a hill,and it really sounds like its coming from right underneath me.....so hopefully a nice NP205 will solve that problem.....thanx.....
Old Nov 27, 2004 | 09:07 AM
fishmanndotcom's Avatar
fishmanndotcom
i have a a complete spare NP205 i will trade ya straight up for the NP203?!?! PM me if ya are interested
-cutts-
Old Nov 27, 2004 | 09:18 AM
brokebronco's Avatar
brokebronco
Ivan, you need to change the picture at the top of your page. Those tires look far too small to be 44s.
Plus, no kegs are in view!
Chris
Old Nov 27, 2004 | 10:54 AM
ivanribic's Avatar
ivanribic
I've been meaning to update my site but haven't had the time. Soon here though.
Old Nov 27, 2004 | 11:58 AM
SwOkcOffRoader
hey are the 205s full time 4x4??? if they arent will it be safe to run my same hubs....i have no clue what the hubs are.... i thought they were autolocks till i found out the truck was full time 4x4.....
Old Nov 27, 2004 | 12:55 PM
ivanribic's Avatar
ivanribic
No, 205's are part time which is one more reason it would be a good switch for you.
Don't know what the reason is for this Aaron, but I believe my truck is 8100 also. Or maybe it's 8600 . . . my memory is failing me, big surprise there.
Old Nov 27, 2004 | 01:01 PM
  #28
monsterbaby's Avatar
monsterbaby
The hubs are probably solid units on a full time 4x4, you can run them but it is like running manual hubs in the lock position all the time, I run those on my race truck but I don't even have linkage on my transfer case it's just locked into 4lo all the time, so if I were you I would look into buying a set of manual hubs for it, or grabbing a sset from the wrecking yard for know if nothing else.
and Ivan you have probably killed more brain cells than alot of people ever had can't imagine why your memory would be slipping (wish I could find a smilly that had a lamp shade on it's head but this will have to do)
Old Nov 27, 2004 | 01:46 PM
  #29
SwOkcOffRoader
ill probably just leave the hubs, when im done with this truck he wont be seeing much pavement, aside from riding on a trailor above it!! its gonna be strickly off road, ill probably weld up my axels, but im thinking about running spools front and rear.....any input on these????
Old Nov 27, 2004 | 02:23 PM
  #30
monsterbaby
I run spools in both axles, and if strictly offroad I say definatly stay with the full time units they are solid one piece design so stronger. As far as welding it is cheaper, but spools for alot of different axles like the 9in are pretty cheap, lighter, and stronger
