Winter Front?
Old Nov 23, 2004 | 11:09 PM
mech2161's Avatar
mech2161
Winter Front?
Anybody using a winter front grille cover. If so what kind. Also I have seen ads for the 205 thermostat. Is it a good investment or not. I'm getting ready to change antifreeze and add a remote filter. Just trying to get all my ducks together and do it all at one time.
Old Nov 24, 2004 | 03:01 AM
Quadzilla's Avatar
Quadzilla
The 203° thermostat is standard equipment on '95's, and is supposed to help you get slightly better mpg's. When I first bought my truck, it had a 185° thermostat in it, so when it needed to be replaced, I went with the 203° model. There is noticeably warmer air coming from the heater now.
There are a number of winter fronts available, though I don't live in a climate that requires one. If I did, I'd have one made like this one. It was custom made for about $40, which is about the same price as some of the plastic inserts would cost.
Old Nov 24, 2004 | 06:05 AM
82F100SWB's Avatar
82F100SWB
I run a Cloud Rider "all season" stainless grille insert in my truck. It doesn't restrict all that much airflow, but, it sure does make a difference compared to not having anything in there.
I'm still undecided as to wether I'm going to get a full blown winter front for it or not, 15F this morning and it warmed up pretty dang quick, and stayed nice and warm. We'll see once I start dealing with -20... LOL
As for the T-stat, the 205 degree will make a very large difference in the heat if you have a 185 in there. I'm unsure what's in mine, but, it sure makes good heat.
http://www.cloud-rider.com/screens_s...y&vhcl_yr=2000
Prices are in Canadian $, click on a price and it'll convert it.
And, my truck:
Old Nov 24, 2004 | 07:17 AM
cangim's Avatar
cangim
There is one through cabela's that is right around 40 buck that comes with summer bug screen as well. Although, depending on the temperatures that you see, where I am at, I really don't need one, the temp of the engine is staying constant between summer and winter.
Old Nov 24, 2004 | 10:34 AM
akpwrstrk's Avatar
akpwrstrk
I have the same grill cover as 82f100, looks sharp. Got it in Alaska and haven't seen many around like it. I leave it on year round. Got a lot of looks/questions as to where I got it while driving from AK through Canada.
I did the same thing last fall when changing fluids, changed the thermostat. Make sure to check coolant with the Fleetguard strips.
Old Nov 24, 2004 | 02:01 PM
77hiboyboy's Avatar
77hiboyboy
I use cardboard and bungee straps.
Old Nov 24, 2004 | 03:15 PM
Domino'sDiesel's Avatar
Domino'sDiesel
I use cardboard and bungee straps.(QUOTE)
SWEET!!
Old Nov 24, 2004 | 07:13 PM
RickyBR's Avatar
RickyBR
what's the pro's and con's of going from 185* and 205* thermostats?
Old Nov 25, 2004 | 01:35 AM
JoeBoost's Avatar
JoeBoost
I have a "cold front" grille screen from Lund that I use every year during the winter months. I don't notice a huge difference , but the truck does get warmer alittle faster than without it.
Old Nov 25, 2004 | 04:56 AM
Quadzilla's Avatar
Quadzilla
The 203° thermostat was OEM on the '95's. They went to a lower temp thermostat on later model trucks. Those that have retrofitted their trucks to accept the 203° thermostat have found that their mpg has improved slightly, and the truck runs better/stronger, slightly.
Diesel engines thrive on heat, and an engine that's fully warmed up will outperform one that isn't. The higher temp thermostat enables the engine to run at a more efficient temperature.
Old Nov 25, 2004 | 09:03 PM
RickyBR's Avatar
RickyBR
What do you have to do to "retrofit" them to accept them. Can't you just change it out? Or do you have to change something else?
LoveDDs
Nov 2, 2012 06:16 PM
alaska F 250
6.4L Power Stroke Diesel
16
Nov 21, 2010 08:12 PM
DEERSHOOTER
25
Mar 2, 2010 06:58 PM
Dirtboy953b
34
Apr 7, 2009 09:50 AM
bigdummyford
Dec 17, 2008 03:13 PM
