condensation
Old Nov 23, 2004 | 01:42 PM
Fire Rooster's Avatar
Fire Rooster
condensation
Here is one for you. Anyone else notice when you use your defroster that you get a condensation drip, like when you use the A/C in the summer? I had never noticed it before.
Old Nov 23, 2004 | 02:01 PM
mech2161's Avatar
mech2161
A/C cycles in defrost mode to keep the system lubed.
Old Nov 23, 2004 | 02:24 PM
warrens250's Avatar
warrens250
The AC runs in defrost mode to dry out the outside air, then reheat it so that it will quickly remove the moisture condensed on the windows as well as melt the frost on the outside. This makes it useful in cool wet climates even though frost is not on the outside of the windows, but the humidity is so high that the inside of the windows fogs up. Turns out on my 2002 it also runs when I switch the selector to the position where air is directed to both the upper vents and the floor. Took a bit of research to find out that this is normal, not a malfunctioning switch!
Old Nov 23, 2004 | 02:38 PM
bluemoose89's Avatar
bluemoose89
i have noticed on mine that when the system is running that it seems to drip alot. almost to a constant stream of water. could there be something wrong?
Old Nov 23, 2004 | 10:20 PM
mech2161's Avatar
mech2161
The more humidity in the air the more it will drip.
Old Nov 23, 2004 | 10:38 PM
farmb0y's Avatar
farmb0y
I've noticed mine doing the same thing, as long as it is from the A/C and not oil or anything else.
6litrefan
Jan 2, 2010 09:25 AM
mantta
Sep 2, 2009 09:56 PM
boatman83
Sep 30, 2004 11:37 AM
3broncocrazy
1978 - 1996 Big Bronco
Oct 13, 2003 12:26 PM
Leland
22
Mar 23, 2002 09:06 PM
