Spark Plug Wires
Old Nov 22, 2004 | 05:18 PM
qman's Avatar
qman
Spark Plug Wires
Does the "wire" part of spark plug wires ever really wear out. In doing a tune-up the other day, a bunch of black dust fell out of the boot when I removed coil wire from the dist cap. That center terminal on the cap was all burnt up and black. So was the connector on the cable end. I think it was loose and arcing. Anyway, I can buy just the single cable and save money over buying a set. I'd rather not buy the entire set if its unecessary.
<!-- / message -->
Old Nov 23, 2004 | 03:33 AM
Ford_Six's Avatar
Ford_Six
The wire itself doesn't wear out specifically, but the insulation around it deteriorates and will cause a voltage leak. This can lead to stalling and stumbling, especially in wet weather, and can also get you zapped pretty good if you touch a wire with the engine running.
mikerans
Jun 11, 2012 09:01 PM
berry1234
Mar 19, 2010 06:47 PM
John Morton
Feb 17, 2009 11:54 AM
abelmoreno
Jul 14, 2008 09:23 PM
qman
General Automotive Discussion
Nov 23, 2004 12:48 AM
