air conditioner
Old Mar 1, 2002 | 05:43 PM
probation144's Avatar
probation144
air conditioner
air conditioner blows out the defrost vents but not out the vents on the dash is there a simple fix for this
Old Mar 1, 2002 | 05:58 PM
destiny88's Avatar
destiny88
air conditioner
If your system has vacum operated vents, chances are that you may have a broken or blcked vacum line. The system is designed that if it loses vacum it will go to defrost for saftey sake.
Old Mar 1, 2002 | 07:55 PM
Ken00's Avatar
Ken00
air conditioner
Yep, defrost is the setting that does not require vacuum so if you lose it that what you get.
Old Mar 2, 2002 | 10:42 AM
probation144
air conditioner
is there any way to fix this other than taking it to the dealer to repair
Old Mar 3, 2002 | 05:23 PM
tomw's Avatar
tomw
air conditioner
What is the year? If mechanical rather than vacuum operated, you may have a loose cable on the mode door lever. Remove the gizzards of the glove box, and look under the dash with a flash or trouble light. While you are moving from panel to defrost, look to see what is moving under the dash on top of the heater box. you should see a lever moving around, if you have cable operated mode door. It mmau have fallen off its proper spot. You should hear vacuum squishing around if you have vacuum operated mechanism, and would see bulby looking things with a flat shaft sticking out that was connected to a door flap. If you don't hear anything, or see anything moving, check for vacuum at the mode switch and if you don't have vacuum, follow the vacuum hose back through the firewall to the reservoir, and the connection to the intake manifold. Look for a loose hose, or a broken hose making sucking noise as the engine idles.
tom
Old Mar 3, 2002 | 06:40 PM
fasteddy_99's Avatar
fasteddy_99
air conditioner
spiffy
1997 - 2003 F150
100
Dec 26, 2023 04:28 PM
Butch(OH)
Jun 20, 2008 06:00 PM
rpage123
Apr 23, 2006 03:33 PM
DailyDriver77
Aug 13, 2004 07:49 AM
ncallas53
Jun 2, 2003 08:38 PM
