Air Conditioner?
Old Aug 12, 2004 | 09:02 PM
DailyDriver77's Avatar
DailyDriver77
Air Conditioner?
My 99f250cc PSD is blowing the air conditioning and heat out of the defroster not any of the other vents. What can you all suggest. Thanks DD.
Old Aug 12, 2004 | 09:07 PM
Gary B's Avatar
Gary B
you have a vacumn leak somewhere or the vacumn pump is bad. defroster is the fail safe mode
Old Aug 12, 2004 | 09:27 PM
DailyDriver77
where is this vacume pump located?
Old Aug 13, 2004 | 06:48 AM
blackf3504dr's Avatar
blackf3504dr
Vacume pump is on the left front of the engine . If it is the vacume pump you will also expierence brake problems ( no power boost ),it may be a split vacume line or a vacume motor that controles the flow doors under the dash .
Old Aug 13, 2004 | 07:03 AM
mueckster's Avatar
mueckster
The '99 and up models have an electric vacuum pump on top of the right fender well. If the pump is good, you should be able to hear it run when you turn on the key. If it is running, remove the line on the pump and check for a suction at the port. If it is OK, then check for bad vacuum lines, vacuum reservoir, or leaking A/C control switch in the dash. I have found, in the past, that the rotary type switch or it's connector will sometimes leak. LOL
Old Aug 13, 2004 | 07:49 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
DD77
If your truck is a 4x4 with automatic hubs you will also have vacuum lines down there that could be causing the problem.
fatfenders
Sep 19, 2002 11:21 PM
acogoff
May 6, 2002 04:31 PM
DeGideo
Apr 27, 2002 12:00 PM
fourtrax
Mar 8, 2002 08:56 PM
KevinT
Mar 16, 2001 11:50 PM
