Sponsored by: Real Truck
Super swamper SSR
Old Nov 20, 2004 | 06:58 PM
birddog16's Avatar
birddog16
Super swamper SSR
I have a 03 F350 V10 FX4 stock height, Does anyone know if the 35x10.50x16 ssr will fit?
Old Nov 20, 2004 | 07:10 PM
DougD's Avatar
DougD
My friend put 35"s on his stock 02 - They weren't SS's but Dunlops I believe.
You may just get a little rubbing on the front air dam but that can be trimmed away. oN THE INSIDE - A LITTLE against the sprins. No big deal. Do it{
Old Nov 21, 2004 | 12:17 AM
02superstroker's Avatar
02superstroker
yeti... you have any ideas?
ha
Old Nov 21, 2004 | 01:15 AM
Uptown83's Avatar
Uptown83
Im sure you could cruise the streets with them but off roading and probaly full turn would rub like crazy
Old Nov 21, 2004 | 08:41 AM
Yeti's Avatar
Yeti
ha
Why yes, yes I do....
Old Nov 21, 2004 | 02:18 PM
bassnmb's Avatar
bassnmb
Swamper tires run more true to size than others. I had a 4" pro comp lift with 35 SSR's and they rubbed a little at full deflection of the steering going into driveways, gas stations etc..... bumped the bottom corner behind each tire. Trimed the bumper at install and no problems there.
Old Nov 21, 2004 | 03:18 PM
birddog16's Avatar
birddog16
Thanks for the imput. looks like the 35' are not the way to go. does anyone have any know what will fit in the ssr line with out rubbing?
Old Nov 22, 2004 | 06:57 PM
oxFord's Avatar
oxFord
Try a set of the ssr in the 32x11.50 size if they have it. Once again since Interco's tires run nearly true to the rating the 32 inch tire is actually 32 inches. I have 33x12.50 dunlop mud terrains and the actual diameter is 32.6 not 33inches. Mine come close but do not rub. yours should clear fine. the stock 265 75r16's are 10.3 inches wide so one more inch should work
PrarieOyster
Feb 13, 2005 11:52 PM
CAT_man_963
Dec 2, 2004 11:15 AM
snipercole
Offroad & 4x4
Sep 22, 2004 11:48 AM
Ford4x4435
1997 - 2003 F150
Dec 12, 2003 10:21 PM
