Cab Corners
Old Nov 20, 2004 | 02:47 PM
Matt66's Avatar
Matt66
Cab Corners
I am getting ready to replace my cab corners. I bought some aftermarket ones that seem to fit good, but what do you do about the inner portion of the cab corner? I can use one from the other side and reverse it, but that means buying two more cab corners.
Any other ideas?
Matt
Old Nov 20, 2004 | 03:04 PM
66 4x4's Avatar
66 4x4
Hey Matt Where Are You Located,im From Spencer In.i Replaced My Cab Corners ,but Was Lucky That The Inner Side Had No Rust.i Dont Think Anybody Makes Those Repo.
Old Nov 20, 2004 | 03:07 PM
lx8950's Avatar
lx8950
I just went through that process. What usually happens is that the drain holes in the cab corners plug up and they fill with water and rust from the inside out. The inside panel is pretty flat and I just replalced it with some flat stock I had on hand. Although we all want our truck to be perfect, the inside of the cab corners will never be seen and don't have to be perfect. Good luck.
Old Nov 20, 2004 | 04:42 PM
Matt66's Avatar
Matt66
I am in Bruceville (by Vincennes), I think you are about an hour North of me on the 67.
The inside of mine aren't flat. They have the same exact curves and bends as the outside. This is on my crew, not my F-100.
I was just looking at it and figured if i cut it high enough, then I could just use flat stock.
Matt
Old Nov 20, 2004 | 05:03 PM
1982fordf100's Avatar
1982fordf100
I just replaced the cab corners on my 82 F100. I know its a different year truck but maybe I could help a bit also. I had to use 18 gauge sheet metal to rebuild a portion behind the cab corners. Most likely your not going to be able to find a company that makes patch panels for the inside of the cab corners. Take a look in my gallery under Restoration pictures. I have some good pictures in there. Maybe it can help you out with your cab corners before you start. Fred
clintonvillian
16
Apr 19, 2022 10:32 AM
reamer
Ford Truck Parts for Sale
Jun 25, 2016 06:56 PM
Chevmn56
Nov 17, 2015 05:56 PM
60FOUR
Dec 30, 2008 05:30 PM
F100man
Paint & Bodywork
Aug 28, 2007 09:39 PM
