BB Turbo
Old Nov 20, 2004 | 02:27 PM
444dieselrod's Avatar
444dieselrod
BB Turbo
I have read about the Ball Bearing upgrade for many SD PSD. and that it is a bolt on install. will the Ball Bearing be a bolt on install on an older psd like the 94-97's. I haven't been able to find the turbo on Motorhavens site to look at it. anyone know where I could look at getting one also???
Diesel rod
Old Nov 20, 2004 | 02:40 PM
wlihntr's Avatar
wlihntr
Diesel rod
you can get a "holset H2E"($2300) for 94-97 psd's it is not a direct bolt on, you have to add an intercooler or fab up an intake for it you can see it at dieselsite . com
Old Nov 20, 2004 | 04:58 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The BB is only a direct swap for the 99.5-2003 trucks.
Old Nov 20, 2004 | 08:06 PM
barebackjake's Avatar
barebackjake
the garret can be made to fit the pre 99's its alot of work though. i helped a buddy with his, came out nice but still alot of work
Old Nov 21, 2004 | 10:30 AM
444dieselrod
So then what is the difference in the 97 to SD turbo that makes them so hard to swap on, i just assumed that ford would use the same turbo set up on the sd that they used on the first powerstrokes, other then the different compressor wheel. and what is a good upgrade to the current turbo, i have read that there only good for like 25 psi for extended periods of time and not much more then that.
Diesel rod
Old Nov 21, 2004 | 04:18 PM
cookie88's Avatar
cookie88
FTE Emeritus
The differences between the turbo's isn't nearly as importamt as the packaging differences. There is a lot less room under the hood of the earlier trucks, so the mount pedestal, the downpipe, intake, outlet manifold etc. etc. are all different. Physically, any 7.3 PSD turbo will bolt to any other pedestal, but the packaging becomes the problem.
barebackjake: would you mind posting the details of the swap?
Old Nov 21, 2004 | 06:01 PM
444dieselrod
Thanks Cookie. Just been brain storming, getting ideas, keeping stuff in the back of my head for when the money starts rolling in pretty good I am gunna need something to spend it on
Barebackjake. Yes Please tell. I am not afraid to do a lil work and the BB turbo is cheaper then an h2e.
Diesel rod
BMWM1
Jun 24, 2009 10:23 AM
ponch37300
16
Jul 29, 2007 10:39 AM
DrivItLkUstoleIt
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Dec 22, 2006 12:02 AM
fordboy2
Oct 4, 2006 09:40 PM
sean23johnson
24
May 31, 2005 05:35 PM
