Pyrometer???
Old Nov 20, 2004 | 11:29 AM
owenlo's Avatar
owenlo
Pyrometer???
Looking for a pyrometer and some that I have found have another option to purchase which is called a "thermocouple". Is this something that needs to be purchased also? What exactly is it? Is there anywhere I can go online and purchase ONE KIT that includes everything I need to install?
Thanks,
Obie
Old Nov 20, 2004 | 12:16 PM
wlihntr's Avatar
wlihntr
the pyrometer is the gauge, the thermol couple is the sending unit(the sensor) you need both. some kits come with them together some are seperate.
http://www.motorhaven.com/customer/home.php?cat=191
Old Nov 20, 2004 | 12:56 PM
vancouverpower's Avatar
vancouverpower
Just make sure you install it before the turbo!!
Old Nov 20, 2004 | 06:26 PM
psdinalaska's Avatar
psdinalaska
Is there a location with a tap already in place for the thermocouple to screw into??
97 PSD auto trans.
Old Nov 20, 2004 | 06:52 PM
psdinalaska
Nuther thought. I was checking out Moterhaven's exhaust system upgrades. One that they advertise "The Full Boar Exhaust", in it's spec sheet, lists it as having a pyrometer plug already installed. This sounds to me like they are saying that the pyrometer thermocouple screws in downstream of the turbo. Which is correct downstream or "before the turbo" as vancouverpower stated in an earler post.
Old Nov 20, 2004 | 07:07 PM
vancouverpower
https://www.ford-trucks.com/forums/s...ght=post+turbo+
Old Nov 20, 2004 | 07:46 PM
psdinalaska
Thanks for the link vancouverpower. I agree it's important to monitor the highest temps. I guess now it's time to look for a spot to install it upstream of the turbo.
Old Nov 20, 2004 | 09:26 PM
wlihntr's Avatar
wlihntr
you have to drill and tap it yourself, the best place is in the drivers side exhaust manifold right before it turns up to the y pipe, its pretty flat and easy to get to. if you do a search on the web for "pyrometer install" you should find a few good sets of instructions, just make sure to be carefull of the metal shavings
Old Nov 20, 2004 | 09:29 PM
Ran440's Avatar
Ran440
owenlo
Summit racing has some nice Auto Meter pyro gauges. They come with a thermocouple. This is what I went with. Mounted the thermocouple pre turbo in the drivers side exhaust manifold about 1 1/2 inches before the up pipe connection. It was very easy to drill and tap. If you would like some pics let me know and I will email some to you.
Randy
Old Nov 20, 2004 | 10:43 PM
dougger222's Avatar
dougger222
I recenlty bought Auto Meter Ultra Light Pro Comp gauges, boost, pyro, and tranny. The pyro gauge was $120, the boost and tranny gauges were $54 each and the Auto Meter pillar pod was $60.
dyoung14
Feb 27, 2009 11:05 PM
7.3blacksmoke
Feb 10, 2008 03:35 PM
linkford
Apr 10, 2007 02:30 PM
skychaney
Computer Chips & Tuners
Feb 9, 2006 10:44 PM
