strange brake light problem
Old Nov 19, 2004 | 08:48 PM
russt's Avatar
russt
i have an 88 f150 302 4x4,
My Brake Lights Dont light Up Unless i have hard pressure on the pedal - which means im having to brake harder in order to ensure my brake lights are lit - under light braking they dont light at all anyone experience this same problem
ireplaced the brake pedal light switch but it acts just the same.
your input will be apreciated
thanks
Old Nov 19, 2004 | 09:07 PM
Guitar_Stitch's Avatar
Guitar_Stitch
Could be an adjustment of the switch. Try re-adjusting it.
Old Nov 19, 2004 | 10:30 PM
russt's Avatar
russt
i thought of that and according to the haynes manual i'm suppose to be able to adjust it - but i dont see how - it's not the gm type where you can adjust a nut to lengthen it - it is a flat rectangle type that i am suppose to be able to bend up or down - while it is installed however it does not seem to act that way - if you know how to do this please let me know.
thanks
Old Nov 20, 2004 | 07:40 PM
russt's Avatar
russt
just thought i'd post this back for anyone else out there who is having the same trouble ( and i know you are cuase i see alot of ford trucks with late brake lights) before the 80's ford used the gm plunger style brake light switch that worked perfectly and was adjustable, somewhere along the line ford thought it was a smart idea to take something that worked so well and replace it with something that doesn't - nor is it adjustable,i just grabbed a switch for a 90 chev pick up from the parts store and fabbed a length of flat bar with a 45 deg bend and attatched it to the lower steering colum mount bracket - i have brake lights "now" again and not just when i'm at a complete stop-
Old Nov 20, 2004 | 08:32 PM
SRD4X4's Avatar
SRD4X4
Just for s***s - giggles, trade in the new switch you bought for another new switch."new does'nt mean good".I just recently went through same problem on a 72 LTD with a "new/bad" brake light switch.
Old Nov 20, 2004 | 10:53 PM
russt's Avatar
russt
thanks but no thanks i tried 5 at the dealer and 2 at the local auto parts store
the gm one is much better- dont get me wrong i luv my ford ..
bigbad79
Mar 31, 2019 01:33 PM
wrd0225
May 4, 2016 03:49 PM
tndallas
Sep 15, 2015 08:14 AM
CF-DRG
Jun 3, 2006 08:23 PM
jsharp921
Nov 12, 2005 07:35 PM
